I was thinking at other different approach to resolve the problem of union of multiple walls with different width or different alignment.
So, we know that the walls union work nice if they are on the same sketch but in this case we can't modific width and allignment singly. Morever, if we draw the wall on different sketchs we can modific width and allignment but at intersection we'll have displeasing lines.
But if we could able to use the constraints betwen different sketchs? Try to explain me better.
We could draw the walls - 30cm width in the sketch A and the walls - 50cm width on the sketch B. Inside of each sketch we'll use the constrains togheter the walls with the same feautures BUT we'll use just one o more constrains to connect the two groups at the specifich points; point to point, point to tangent, etc. from sketch A to sketch B
Is it too hard develop this feature? can this approac resolve the problem?
If YES you can reply this message ... if NO this message will be destroyed in 10 secons ... 9 ... 8 ... 7 ...
