Macro error: No module named 'gui_arrays'
spanner888
Post by spanner888 »
In FC 0.19.20477:-
Recorded macro creating Draft array creation and when running macro, get error below.
File "C:/Users/spanner888/AppData/Roaming/FreeCAD/Macro/no_module_error.FCMacro", line 5, in <module>
import gui_arrays
<class 'ModuleNotFoundError'>: No module named 'gui_arrays'
Steps to reproduce:
Create new FC doc, add a default Part WB cylinder.
Switch to Draft WB & record a macro of creating a default Array of the cylinder.
Stop recording macro
Delete array
Select cylinder, run macro.
workarounds I have found are to
add either:
import DraftGui
or
import Draft
AND comment out
#import gui_arrays
#import gui_orthoarray
#import gui_polararray
Note original macro also added a polar array and tweaked the default array, hence the two additional imports.
Issue does not occur in FC 0.18 and macro does have "import DraftGui" and does NOT have the 3 problematic imports.
Possibly related to this commit which seems to have removed "import DraftGui"
OS: Windows 10 (10.0)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Python version: 3.6.8
Qt version: 5.12.1
