problems with Freecad 0.19
several problems with Freecad 0.19.
1) does not make windows fit into the wall;
2) completely freezes when importing IFC files;
3) when I open a file made with version 0.18 in which there are measures insert through the Formula Editor and save it with 0.19, when I reopen it with 0.18 the measures have lost the reference to the formulas
OS: Windows 10 (10.0)
Version: 0.19.20738 (Git)
Hash: 0c96f77184edc0a6747483b2ff1462fc6dae46ff
Python version: 3.6.8
Qt version: 5.12.1
Locale: Italian/Italy (it_IT)
Qt version: 5.12.1
- problem windows.JPG (363.12 KiB) Viewed 3622 times
- problem with IFC import 2.JPG (298.5 KiB) Viewed 3622 times
Re: problems with Freecad 0.19
0.19 Appimage Many Errors pointing to /temp/.mount
Do not mix 0.18 and 0.19 like that. The newest version 0.19 has introduced many new changes to the expression engine and formula editor, so if you go back to 0.18 it will not work. If you start with 0.18 you can only move to 0.19 once. After that you must stay with 0.19.3) when I open a file made with version 0.18 in which there are measures insert through the Formula Editor and save it with 0.19, when I reopen it with 0.18...
Another problem,
when we want to do Map mode of a sketch (deactivate), to constrain it all objects disappear (except the sketch itself) and therefore we cannot select any object to constrain it to
- problem with Map Mode Deactivate.JPG (302.18 KiB) Viewed 3565 times
Hello
There seems to be several bugs with the tools&workbenches in the latest daily build. When loading BIM-workbench, most tools are not loaded:
When loading Draft-Workbench:
etc. ....
My system-info:
Just reporting...
No module named 'draftviewproviders.view_bspline'
File "<string>", line 69, in Initialize
File "/usr/share/freecad-daily/Mod/Draft/DraftTools.py", line 49, in <module>
import Draft
File "/usr/share/freecad-daily/Mod/Draft/Draft.py", line 222, in <module>
from draftmake.make_bspline import make_bspline, makeBSpline
File "/usr/share/freecad-daily/Mod/Draft/draftmake/make_bspline.py", line 39, in <module>
from draftviewproviders.view_bspline import ViewProviderBSpline
module 'FreeCADGui' has no attribute 'Snapper'
File "<string>", line 134, in Activated
File "/usr/share/freecad-daily/Mod/Draft/draftutils/init_draft_statusbar.py", line 342, in show_draft_statusbar
init_draft_statusbar(sb)
File "/usr/share/freecad-daily/Mod/Draft/draftutils/init_draft_statusbar.py", line 223, in init_draft_statusbar
Gui.Snapper.init_draft_snap_buttons(snap_gui_commands,snaps_menu, "_Statusbutton")
My system-info:
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu-wayland)
Version: 0.19.
Branch: unknown
Hash: bd86e1cb67c01f8085ee1e48324b5694187bd399
Python version: 3.6.9
Qt version: 5.9.5
Hello, thanks for reporting, the issue is related to the massive code reorganization we are carrying on, and the bug i introduced should be already fixed, thanks to a common effort!
try next build to see if everything went back to normality
Pull request #3414. The fix should be integrated into the daily build within one or two days.
Daily build: Draft WB gone
Hi, Thanks
I continue to put information on the use of 0.19, checking and thinking of giving help.
I have tried the version
Version: 0.19.20839 (Git)
Hash: 09005766f10539dfe32314c33c2cd3efe9141d0b
Qt version: 5.12.1
1) as regards the creation of windows and doors, the problem remains
REPORT
"Running the Python command 'Arch_Window' failed:
File "C:\Users\user\Downloads\freeware\programmi cad free\FreeCAD_0.19.20839_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Arch\ArchWindow.py", line 664, in Activated
FreeCADGui.Snapper.getPoint(callback=self.getPoint,movecallback=self.update,extradlg=self.taskbox())
File "C:\Users\user\Downloads\freeware\programmi cad free\FreeCAD_0.19.20839_x64_LP_12.1.2_PY3QT5-WinVS2015\Mod\Arch\ArchWindow.py", line 788, in taskbox
presetdir = os.path.join(FreeCAD.getUserAppDataDir(),"Arch")
local variable 'os' referenced before assignment"
2) the problem of the deactivated sketch remains, that all objects disappear to constrain the sketch
3) instead it now manages to import IFC files.
But it seems to me that it matters too many references (double building and layer) and it seems that the objects appear twice
Qt version: 5.12.1
REPORT
- schetch deactivate.JPG (185.13 KiB) Viewed 3464 times
- ifc import.JPG (168.79 KiB) Viewed 3464 times
- thomas-neemann
I had the same problem. after deleting .FreeCAD and ./config/FreeCAD everything was ok again
Please put a warning message that file saved in 0.19 can't be opened on 0.18.
0.18 plugin manager is broken which has to use 0.19 to install plugin and go back to 0.18. Sometime, you use 0.19 to draw a few things but accidentally saved the file. The file can't be reopened on 0.18. However, 0.19 is under development that still not suitable to be used for real work.
I spent two days to draw a part on 0.18 but accidentally saved on 0.19 that can't continue my work on 0.18!
Why don't you continue in 0.19? That would save you two days work. It is normal behaviour, that new versions of a program work with old files, but not vice versa. This was discussed just yesterday in another post (probably in Help forum).poontitming wrote: ↑Thu Jan 14, 2021 9:11 pm I spent two days to draw a part on 0.18 but accidentally saved on 0.19 that can't continue my work on 0.18!
