[SOLVED and PR Merged] Ticket #4400 - Arch wall created from wire, fails.
System:
OS: Debian GNU/Linux 10 (buster) (GNOME/gnome)
Version: 0.19.21823 (Git)
Hash: 25a4cf67d53bb270f6ab7c8c5f9ef5601c194e76
Python version: 3.7.3
Qt version: 5.11.3
Steps to Reproduce:
Create a wire with the shown geometry, select wire press arch wall. The wall will be created missing two sides and with some cutoffs.
Qt version: 5.11.3
Steps to Reproduce:
- Fail_Example.FCStd
- (11.81 KiB) Downloaded 42 times
Re: Arch wall created from wire, fails.
There were some changes to Arch Wall recently to improve the use of walls with Sketches, git commit 81dd47b0393.
However, I'm afraid the changes were only tested with Sketches and not with regular Draft Wires. Try reverting the changes and see if that fixes the problem.
The Wall works well if the Wires are converted to Sketches with Draft_Draft2Sketch.
Not sure where exactly is the problem atm, please file in Mantis tracker and assign to me, thanks.
In the meantime, like @vocx suggests, convert to Sketch to make it works.
Mind to test below fix ?
Seem Part.SortEdges return edges/vertexes in expected order but direction reversed for DWire as input ?
Replace below ArchWall.py in the Arch module.
self.basewires = obj.Base.Shape.Wires
# Found case that after sorting below, direction of
# edges sorted are not as 'expected' thus resulted in
# bug - e.g. a Dwire with edges/vertexes in clockwise
# order, 1st vertex is Forward as expected. After
# sorting below, edges sorted still in clockwise order
# - no problem, vertexes still in clocwise order - no
# problem, but 1st vertex of each edge become Reverse
# rather than Forward.
# See FC discussion -
# https://forum.freecadweb.org/viewtopic.php?f=23&t=48275&p=413745#p413745
#self.basewires = []
#for cluster in Part.getSortedClusters(obj.Base.Shape.Edges):
# for c in Part.sortEdges(cluster):
# self.basewires.append(Part.Wire(c))
- Fail_Example_ finding bug.FCStd
- (34.86 KiB) Downloaded 37 times
FWIW - tested as per instructions. I was able to reproduce the error.
After updating to the new ArchWall.py script, error was fixed.
Good job!
OS: Windows 10 (10.0)
Version: 0.19.21832 (Git)
Hash: 31b1ad874fb4750b6f6f25b494246f6ac7e61cde
Python version: 3.6.8
Qt version: 5.12.1
Good job!
Qt version: 5.12.1
Thanks for testing !mikeprice99 wrote: ↑Sat Jul 04, 2020 7:48 am FWIW - tested as per instructions. I was able to reproduce the error.
Would you mind to create a bug report ?
I do not use DWire in my models so there are not enough tests. Hope more peoples use DWire as Base of Wall can test before I create a PR
Then start doing it. You are breaking the previous code because you don't test enough. Stop doing that. The Arch workbench is based on the Draft Workbench, so you need to check that Draft workbench features work before you make changes. Stop being so self-centered, and realize there is more things that you need to consider before making big changes to the code.
I have reported the issue on Mantis as issue #4400
I did not know how to assign it to @Paullee.
Thanks for the hard work! FreeCAD is Amazing!
Reason: added [bug] bbcode
Thanks, I find I can't assign it to myself either ... ?hhassey wrote: ↑Mon Jul 06, 2020 5:44 am I have reported the issue on Mantis as issue #4400
@Kunda any idea ?
Re: Ticket #4400 - Arch wall created from wire, fails.
Done
