Open Source House with Open Source CAD?
thomas-neemann
Postby thomas-neemann » Tue Jul 28, 2020 8:40 am
to prove the practicability of freecad, we could create this open-source house incl. ifc file here in the forum. who wants to participate?
https://www.stylepark.com/de/news/open- ... studiolada
http://www.studiolada.fr/docs/telecharg ... nthese.pdf
bodenplatte3.ifc
(9.3 KiB) Downloaded 145 times
Bildschirmfoto vom 2020-07-28 10-35-40.png (15.84 KiB) Viewed 2495 times
falls ein video-link von mir schwarz und nicht anklickbar sein sollte, hier der kanal: https://www.youtube.com/channel/UCVcztV ... 03GgKekj_g
es ist auch möglich auf antworten zu klicken um den link zu sehen.
thomas-neemann
Re: Open Source House with Open Source CAD?
Postby thomas-neemann » Tue Jul 28, 2020 10:59 am
to export ifc files it is often better to work with simple copy.
in this example it is extrusion. it is the same for array and shifted groups.
https://forum.freecadweb.org/viewtopic. ... 05#p419572
Bildschirmfoto vom 2020-07-28 12-44-45.jpeg (55.51 KiB) Viewed 2455 times
edit
this windows are made with copy/paste and draft move. it works great.
fenster.ifc
(95.84 KiB) Downloaded 112 times
Bildschirmfoto vom 2020-07-28 13-55-57.png (55.71 KiB) Viewed 2438 times
paullee
Postby paullee » Tue Jul 28, 2020 3:40 pm
Sounds interesting, I have been trying to build some models exploring a workable and efficient workflow. Extremely busy at the moment but would like to test any suggested workflow.
How do you like to collaborate ?
In fact, if possible, always hope there are structural engineer, building services engineer etc. to work together so it looks more like a real project.
thomas-neemann
Postby thomas-neemann » Tue Jul 28, 2020 3:51 pm
paullee wrote: Tue Jul 28, 2020 3:40 pm Sounds interesting, I have been trying to build some models exploring a workable and efficient workflow. Extremely busy at the moment but would like to test any suggested workflow.
i am an engineer and support some companies that want to switch to freecad. i want to show that it is possible to work with freecad professionally and fast. also big projects.
we could build this house complete in freecad with all the details and with the use of ifc we could put together the different trades.
thomas
thomas-neemann
Postby thomas-neemann » Tue Jul 28, 2020 4:07 pm
here is a quick way to create sections (with stairs). convert everything into a mesh, create section, activate stairs, measure in draft, print as pdf a0 and colorize inkscape.
Bildschirmfoto vom 2020-07-28 17-32-01b.jpeg (76.51 KiB) Viewed 2364 times
Bildschirmfoto vom 2020-07-28 17-29-20.jpeg (86.32 KiB) Viewed 2364 times
Bildschirmfoto vom 2020-07-28 17-27-53.jpeg (26.69 KiB) Viewed 2364 times
paullee
Postby paullee » Tue Jul 28, 2020 4:24 pm
Why meshing it ?
thschrader
Postby thschrader » Tue Jul 28, 2020 4:28 pm
There were (are) discussions in the german forum about loading/converting very large ifc-files for using in FC.
https://forum.freecadweb.org/viewtopic.php?f=13&t=48318
https://forum.freecadweb.org/viewtopic.php?f=13&t=49005
When I understand Thomas Neemann correct, this is a BIM-Project using Freecad but the collaboration uses ifc-files alone.
Thomas, right?
My questions:
Should we use the BIM-wb?
What about the level of detail? (rebars, details of connections…)
Including topography around the house?
Should we construct an exact replica or “freestyle”?
I am a structural engineer (steel construction), I can give some statics-mustard…
And I am very busy too atm…however…
thomas-neemann
Postby thomas-neemann » Tue Jul 28, 2020 4:29 pm
paullee wrote: Tue Jul 28, 2020 4:24 pm Why meshing it ?
i do it for several reasons. the slow techdraw can be avoided for editing. if large ifc files are added as mesh, they can be edited quickly and can also be seen in cut
thomas-neemann
Postby thomas-neemann » Tue Jul 28, 2020 4:37 pm
thschrader wrote: Tue Jul 28, 2020 4:28 pm ping
thanks for your cooperation
I don't know the bim wb yet. If someone works with it, that's good. We get insights.
only ifc is the goal. it should be possible in principle. if in individual cases there are faster ways which are accepted, the methods can be mixed.
my customers do not want a limit and it should be fast.
thomas
paullee
Postby paullee » Tue Jul 28, 2020 5:17 pm
Thomas, right?
My questions:
Can't read german :) Very long discussion !
Arch and BIM WB is basically same.
And there are a lot of aspects I haven't understood how to do - exaclty e.g. LoD, external topography (Geomatic WB seems good, being integrated into Trail)
Lot of gaps to fill :D
