Open Source House with Open Source CAD?
johnwang
Re: Open Source House with Open Source CAD?
Postby johnwang » Sat Aug 01, 2020 6:40 am
thomas-neemann wrote:
Sat Aug 01, 2020 6:26 am
can freecad fem do that?
Fem just do the calculation, You have to use the building code to justfy your design. Sometimes the code is much easy than fea, so fea is just a waste of time and hard to get a certificate. Because the certifier don't understand fea. He just use the building code.
thomas-neemann
Postby thomas-neemann » Sat Aug 01, 2020 6:44 am
this is about confirming the practicality of freecad. therefore we can also work with fictitious data here
thomas-neemann
Postby thomas-neemann » Sat Aug 01, 2020 6:45 am
thomas-neemann
Postby thomas-neemann » Sat Aug 01, 2020 7:22 am
I searched a long time for an ifc file for attaching a slar panel to a trapezoidal sheet, but didn't find anything.
most of it is for revit or archicad.
I often hear that as an argument against freecad that there are few parts for freecad to lode down.
so revit and archicad are only half the solution, because it doesn't contain any BIM-data. in the end it will be necessary that everything is available as ifc and then all cad systems are equivalent at that point.
thschrader
Postby thschrader » Sat Aug 01, 2020 8:29 am
paullee wrote:
Fri Jul 31, 2020 6:51 pm
Roof profile / height not matching - information not enough on pdf :lol:
pink lines = new reference for roof?
thomas-neemann
Postby thomas-neemann » Sat Aug 01, 2020 8:32 am
ping
suggestion: when thschrader creates the wooden structure, he also creates the reference. at the same time
paullee
Postby paullee » Sat Aug 01, 2020 8:39 am
Thanks checking :)
In fact, I note there is some information on the pdf, just need to include the external finishes / cladding into overall dimensions and should do ...
See below screencapture, there are dimensions setting-out the ridgeline.
Screenshot from 2020-08-01 16-37-10.png (55.05 KiB) Viewed 138 times
paullee
Postby paullee » Sat Aug 01, 2020 9:12 am
bernd wrote:
Fri Jul 31, 2020 10:01 pm
More weird results - seem Part Extrusion against IFCexport has something imcompatible in some cases - it seem Meter be interpreted as Millimeters ?
(In addition to the extrusion direction problem)
I place the Sketch for extrusion over opposite wall, so to ensure the subtraction volume if extruded in that particular direction cut the wall.
It cut, but the extrusion volume become extremely long :shock:
Wall_Test_22_FullParametric_git 21329.ifc
(23.77 KiB) Downloaded 3 times
Wall_Test_23_git 21329.ifc
(8.14 KiB) Downloaded 4 times
Screenshot from 2020-08-01 17-02-18.png (116.27 KiB) Viewed 121 times
Screenshot from 2020-08-01 17-02-57.png (118.29 KiB) Viewed 121 times
thschrader
Postby thschrader » Sat Aug 01, 2020 9:19 am
edit: (forgot text...)
at the moment we have 4 different layouts. Which one to use?
paullee
Postby paullee » Sat Aug 01, 2020 9:25 am
OK, I modify the roof outline per pdf information.
House_01_OpenSource.FCStd
(653.1 KiB) Downloaded 8 times
Screenshot from 2020-08-01 17-21-47.png (252.57 KiB) Viewed 112 times
Screenshot from 2020-08-01 17-23-29.png (234.57 KiB) Viewed 112 times
