Open Source House with Open Source CAD?
paullee
Re: Open Source House with Open Source CAD?
Postby paullee » Fri Jul 31, 2020 5:21 pm
bernd wrote:
Fri Jul 31, 2020 5:42 am
no problems here with your file.
Hmmm...I test with your file on
- FreeCAD_0.19-21775-Linux-Conda_glibc2.12-x86_64.AppImage
- FreeCAD_0.19-21329-Linux-Conda_glibc2.12-x86_64.AppImage
and still can't get your result.
Can you post your ifcImport/ Export setting for reference.
BTW, I had no problem in export wall with subtraction in the Villa Savoye model... maybe need to test that model again ....
Thanks !
paullee
Postby paullee » Fri Jul 31, 2020 5:25 pm
thomas-neemann wrote:
Fri Jul 31, 2020 2:29 am
paullee wrote:
Thu Jul 30, 2020 11:25 pm
ping
if i take your file and copy the wall with part simple copy, i can create a correct ifc from it.
Thanks for testing.
But the issue is to use Arch Object such that IfcExport create IFC file with attributes built-in in the Arch Objects.
Part Objects won't have that information in 'BIM'
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 5:33 pm
....But the issue is to use Arch Object such that IfcExport create IFC file with attributes built-in in the Arch Objects.
I know, but I would now like to offer my customers something to start with. in a second step, everything else like attributes etc. can be added at some point.
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 6:14 pm
my customers often have to plan outdoor facilities by truck.
special software is used for this. here is a free option.
in our case, it could be used to check the position of the garage
https://autoturnonline.com/de/
phpBB [video]
Bildschirmfoto vom 2020-07-31 20-10-41.png (60.35 KiB) Viewed 105 times
bernd
Postby bernd » Fri Jul 31, 2020 6:24 pm
Thanks !
very strange ... what version of ifcopenshell do you have?
import ifcopenshell
ifcopenshell.version
bernd
Postby bernd » Fri Jul 31, 2020 6:27 pm
thschrader wrote:
Fri Jul 31, 2020 1:53 pm
Added some more wooden beams/columns.
Hard to find the exact geometry. I am wondering about the
static stabilty... :?
wood_structure_roof_columns.ifc
the big problem is, only the architecture drwings are open source not the manufactur drawings, neither of concrete, nor of wood nor of the mep. :cry:
thomas-neemann
Postby thomas-neemann » Fri Jul 31, 2020 6:30 pm
ping
we can use the photos as a basis, we can define everything that is missing.
paullee
Postby paullee » Fri Jul 31, 2020 6:47 pm
Thanks !
import ifcopenshell
It is built-in AppImage... I suspect it is something about IfcExport setting ?
>>> import ifcopenshell
'0.6.0b0'
bernd
Postby bernd » Fri Jul 31, 2020 6:49 pm
once started with wrong work flows it is difficault to change them, thus +1 to paullee. At least the IfcObjectTyp and the material should be set for a Ifc export!!!
Thus Arch Component should be used, which is very easy in FreeCAD because anything could be a Arch Component. Just select the object and click on Arch structure.
Attributes and psets could be added at any time later on according BIM project standards.
paullee
Postby paullee » Fri Jul 31, 2020 6:51 pm
Some model updating, merged IFC / FC downloaded
House_01_OpenSource.FCStd
(646.3 KiB) Downloaded 6 times
Roof profile / height not matching - information not enough on pdf :lol:
Screenshot from 2020-08-01 02-47-59.png (446.32 KiB) Viewed 89 times
Screenshot from 2020-08-01 02-48-16.png (254 KiB) Viewed 89 times
Screenshot from 2020-08-01 02-48-42.png (476.85 KiB) Viewed 89 times
