best way to draw 2D steel column view
ebrahim raeyat
Re: best way to draw 2D steel column view
Post by ebrahim raeyat »
Kunda1 wrote: Wed Dec 16, 2020 11:53 am
yorik wrote: Wed Dec 16, 2020 11:45 am Would you be interested in having your WB added to the FreeCAD addons Ebrahim? It looks pretty advanced already...
Was just thinking this :lol:
Thank you, @Kunda1, how can I add it?
Post by Kunda1 »
ebrahim raeyat wrote: Wed Dec 16, 2020 7:21 pm
Yorik, I'm not sure if the add-on manager would install all the needed components for this workbench.
ebrahim raeyat
Kunda1 wrote: Wed Dec 16, 2020 8:20 pm Yorik, I'm not sure if the add-on manager would install all the needed components for this workbench.
It only needs EZDXF package.
Post by Kunda1 »
So we're going to need to tell folks to install it somehow. Or we do something else like install it via FreeCAD-pip ?
yorik
Founder
Post by yorik »
Okay I added SteelColumn to the addons! Welcome on board :)
About the EZDXF dependency: you can add a metadata.txt file in your repo's root dir, and inside:
[dependencies]
pylibs=ezdxf
(Check for example https://github.com/jmplonka/InventorLoa ... tadata.txt )
ebrahim raeyat
yorik wrote: Thu Dec 17, 2020 2:51 pm Okay I added SteelColumn to the addons! Welcome on board :)
[dependencies]
pylibs=ezdxf
Thanks, @yorik. I added metadata.txt file with content you said.
MikaelT
Post by MikaelT »
I have a very general question. Iam trying to assemble a bridge structure using std building elements such as beam, joint, rod. Also Iam in a need to show type indications suck as reactions on eccentricities and set of symbols for that.
I know there are workbenches such as BIM and dodo. Currently I am not sure if these covers my needs or if there are additional libraries fot this to add
Do you know if there are additions specifically for these type of drawings ?
Regards
Mikael
ebrahim raeyat
MikaelT wrote: Wed Sep 07, 2022 10:33 am Also Iam in a need to show type indications suck as reactions on eccentricities and set of symbols for that.
Regards
Mikael
Hello @MikaelT . If I understand you correctly, you can use TechDraw WB for this.
