Hi All,
I am new in freecad and is very excited about starting to use Freecad in my work. I was trying to position columns in grid intersections. However, the columns are getting placed in all grid intersections. This doesn't help much as all the columns are not of same size and I would like to position different columns in different intersections. Also, would be great if there any way of even changing the a few column to be offset from the main grid too. Is there any way of positioning the columns in only a few selected grid intersections.
Thanks again for the wonderful work that is being done here.
Columns positioning in selective grid location
Re: Columns positioning in selective grid location
Using the Axis property of the column only makes sense if you want the same column on all intersections of your Arch_AxisSystem. Why don't you place individual columns? And maybe use clones and Draft arrays where appropriate?
