Great, give me a heads up when you're ready. Then I'll add the workbench to the Addon Manager
SketchArch Addon [Comments Request /PR] - Intuitive Automatic Windows/Doors + Equipment Placement
Re: [ Comments Request ] Intuitive Automatic Windows/Doors + Equipment Placement
Thanks, found it already stated as experimental https://github.com/paullee0/FreeCAD_Ske ... /README.md
Would further update the installation section when it could be installed via Add-on Manager.
Just this will do? Seems much simpler than I thought.
Hope it worth your effort
Some pointers:
Populate the feedback section of the readme explaining for further discussion link to this form thread.
Add a license file and link to it from the readme
Update the install section by mentioning that the workbench is now available via the addon manager link to the add-on manager wiki page from the readme
- ragohix769
Good news!
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
Done, please checkKunda1 wrote: ↑Fri Jun 11, 2021 1:05 am Some pointers:
Thanks.
Made some PRs. Please add some succinct bullet points regarding features of the workbench, i left you bulletpoints to fill in.
Also consider choosing some images/screencasts that you'd like to be featured on the README
Let me know if you need any help. Give me a heads up if you're done.
Kunda1 wrote: ↑Fri Jun 11, 2021 8:11 pm Made some PRs. Please add some succinct bullet points regarding features of the workbench, i left you bulletpoints to fill in.
Thanks! Done some further reformatting, adding some images and icons
It's a good exercise to organise my thoughts indeed.
And should have some wiki on how to use the few Gui Commands.
Hello Paullee, I have been watching your project for some time, and wanted to test it out, but I encounterd a problem when I create the ArchSketch and try to add lines to it. This is the error:
OS: Windows 10 (10.0)
Version: 0.19.23463 (Git)
Hash: adc6db8f32c17e9f67cb82aa7962d1e42ce061c6
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
13:59:34 Traceback (most recent call last):
File "C:\Users\stefa\AppData\Roaming\FreeCAD\Mod\Sketch Arch\ArchSketchObject.py", line 234, in execute
self.updateSortedClustersEdgesOrder(fp)
File "C:\Users\stefa\AppData\Roaming\FreeCAD\Mod\Sketch Arch\ArchSketchObject.py", line 246, in updateSortedClustersEdgesOrder
clEdgePartnerIndex, clEdgeSameIndex, clEdgeEqualIndex, clEdgePartnerIndexFlat, clEdgeSameIndexFlat, clEdgeEqualIndexFlat = getSketchSortedClEdgesOrder(fp)
File "C:\Users\stefa\AppData\Roaming\FreeCAD\Mod\Sketch Arch\ArchSketchObject.py", line 1168, in getSketchSortedClEdgesOrder
if not construction:
<class 'UnboundLocalError'>: local variable 'construction' referenced before assignment
Qt version: 5.12.5
OCC version: 7.4.0
I see, thanks for trying. @abdullah introduced a facadeList property for Sketch at some point and retire the construction, I thought my test in the code make it backward and forward-compatible but it seems notABeton wrote: ↑Sat Jun 12, 2021 12:04 pm...Code: Select all
13:59:34 Traceback (most recent call last): File "C:\Users\stefa\AppData\Roaming\FreeCAD\Mod\Sketch Arch\ArchSketchObject.py", line 1168, in getSketchSortedClEdgesOrder if not construction: <class 'UnboundLocalError'>: local variable 'construction' referenced before assignment
Update your FC to at least git 23756 and test, it is my working copy and it should work.
(Before I may attempt to make it 'early_0.19-pre compatible' )
Ok I tried it with the newest build... This is some great stuff Being able to edit alignement and width of single walls in a sketch is perfect. I like it that the object tree is kept really simple in this way, architects should not deal with big object trees.
So some observations of which you are probably also aware off. It is not very intuitive at the start, because it should have the wall command inside the workbench. Placement of objects in a mathematical way is slow also. But this is a work in progress of course, so it takes time. What matters is the principle and I think this could really work
Now seeing this I realise that we really need to have graphical commands inside the FreeCAD view. So if I want to move a window, to have some icons next to the window which allow me to do this. Also for walls, if the wall is clicked that the dimensions of the wall are displayed next to it and can be changed in an easy way. And so on, we need these ease of use things to make the workbench and FreeCAD in general attractive for more architects.
I need to finish the library stuff I have been working on, and than I will go through your code to understand it better. I am still in the process of understanding what would be the best workflow for doing architecture in FreeCAD and if this i it I could help you out if you want, perhaps by creating the graphical interface(first I need to learn how to do it of course )
