SketchArch Addon [Comments Request /PR] - Intuitive Automatic Windows/Doors + Equipment Placement
Re: SketchArch Addon [Comments Request /PR] - Intuitive Automatic Windows/Doors + Equipment Placement
Looks better with Shadow on Link Branch
Re: [ Comments Request /PR ] Intuitive Automatic Windows/Doors + Equipment Placement
NiCE!!!
In response to a comment on a youtube video, I try to centralise available resources by adding Youtube videos immediately at the Github ReadMe for better illustration of the SketchArch add-on features :-
https://github.com/paullee0/FreeCAD_Ske ... /README.md
Hope it helps in the meantime (before more time and resources available to extract previous step by step into a wiki / tutorial, or adding voice over the video).
- jsolersallent
Thank you very much:))
I tried to update the workbench with the latest Archsketchobject.py file and two menu icons have disappeared.
- Screenshot 2022-05-22 10.39.58.png (88.62 KiB) Viewed 1775 times
jsolersallent wrote: ↑Sun May 22, 2022 8:47 am Thank you very much:))
Welcome and thanks for the interest and testing
I have a look and it seems to be the Create Voxel and Create CellComplex buttons. Not sure if something wrong I did on the Github, will have a look.
Anything you see on Report View?
Do you find the last 2 commands in the drop-down menu on the Sketch Arch menu bar ?
Seems nothing wrong on the Github, you have the Voxel.svg and CellComplex.svg in your .../icons/ directory ?
Just note from the Report window of your screencapture, the command Voxel and CellComplex are not found. Maybe you are not using all the files from the Github.jsolersallent wrote: ↑Sun May 22, 2022 8:47 am I tried to update the workbench with the latest Archsketchobject.py file and two menu icons have disappeared.
Just download all the files from the Github - https://github.com/paullee0/FreeCAD_SketchArch ...
> Find the CODE button, click it, and select Download ZIP. Unpack in your pc and place those files/directory in your FreeCAD.../Mod/ directory.
Hope it helps
- jsolersallent
I receive from report view the messages: unknown commmand "Cellcomplex" and unknown command "Voxel". In mod/sketcharch/Icons I see Cellcomplex.svg and Voxel.svg.
I assume that the last update of SketcharchObject.py was in the post August/1/2021 https://forum.freecadweb.org/viewtopic. ... 19#p521119
If I do the installation from Githup without replacing the original SketcharchObject it seems to work and I just need to add Archwindow.py and ArchEquipment.py that are not in the zip file.
Ok, I see the confusion in your casejsolersallent wrote: ↑Sun May 22, 2022 2:18 pm I assume that the last update of SketcharchObject.py was in the post August/1/2021 https://forum.freecadweb.org/viewtopic. ... 19#p521119
Just use the latest 0.20_pre-release version of FreeCAD downloadable at https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
(The 0.20 official release version is in progress though) The ArchWindow.py, ArchEquipment.py etc. had already been merged in the pre-release version, so no need to replace those manually.
Then, just use the whole SketchArch download at Github.
Maybe I need to add a remark in the Github Readme of the SketchArch
[EDIT : Done]
