Thanks!twohot wrote: ↑Thu Dec 14, 2017 2:20 pmIt doesn't appear that you understood my hint. You should not be looking for qt4. It is simply "qt"paullee wrote:Try a few combination ... searching for qt5-dev / qt3-dev return something, but 'qt4' + 'dev' only return qdevelop.x86_64 - Installing the latter doesn't resolve the problem, same error message....
I have not much idea (no in fact).
I am currently compiling IfcPlusPlus after performing the following:
dnf install qt-devel, OpenSceneGraph-devel
It is "qt" .... yes, just "qt" without "4" prefixbernd wrote: what is your standard qt on fedora?
Same here - carefully reading some rpmfind like website lead me to realize there is no '4' after 'qt'!
Seems overcome this problem, though more errors now....
Would try install OpenSceneGraph-devel as you indicated above and guess what other errors are about.
[paullee@f25--80G-Hdd--c2duo build]$ cmake ../
-- Boost version: 1.60.0
-- Linux OS --> Qt4 is used
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found
-- Found Qt4: /usr/bin/qmake-qt4 (found version "4.8.7")
-- Could NOT find osgDB (missing: OSGDB_LIBRARY OSGDB_INCLUDE_DIR)
-- Could NOT find osgUtil (missing: OSGUTIL_LIBRARY OSGUTIL_INCLUDE_DIR)
-- Could NOT find osgGA (missing: OSGGA_LIBRARY OSGGA_INCLUDE_DIR)
-- Could NOT find osgFX (missing: OSGFX_LIBRARY OSGFX_INCLUDE_DIR)
-- Could NOT find osgSim (missing: OSGSIM_LIBRARY OSGSIM_INCLUDE_DIR)
-- Could NOT find osgText (missing: OSGTEXT_LIBRARY OSGTEXT_INCLUDE_DIR)
-- Could NOT find osgQt (missing: OSGQT_LIBRARY OSGQT_INCLUDE_DIR)
-- Could NOT find osgViewer (missing: OSGVIEWER_LIBRARY OSGVIEWER_INCLUDE_DIR)
-- Could NOT find osg (missing: OSG_LIBRARY OSG_INCLUDE_DIR)
-- Could NOT find OpenThreads (missing: OPENTHREADS_LIBRARY OPENTHREADS_INCLUDE_DIR)
CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find OpenSceneGraph (missing: OPENSCENEGRAPH_LIBRARIES
OPENSCENEGRAPH_INCLUDE_DIR OSGDB_FOUND OSGUTIL_FOUND OSGGA_FOUND
OSGFX_FOUND OSGSIM_FOUND OSGTEXT_FOUND OSGQT_FOUND OSGVIEWER_FOUND
OSG_FOUND OPENTHREADS_FOUND)
/usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:377 (_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake/Modules/FindOpenSceneGraph.cmake:223 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
SimpleViewerExample/CMakeLists.txt:49 (FIND_PACKAGE)
-- Configuring incomplete, errors occurred!
See also "/home/paullee/IfcPlusPlus-master_Bernd-repo/build/CMakeFiles/CMakeOutput.log".
See also "/home/paullee/IfcPlusPlus-master_Bernd-repo/build/CMakeFiles/CMakeError.log".
