[FIXED] Ticket #4301 - Draft Pattern problem (upstream coin3d API change)
clifcox
Post by clifcox »
Hi Folks,
sorry for reopening this old thread, but I think there might be a regression here between 0.18 (where it works) and 0.19 (where it doesn't). I was following the the draft WB tutorial in the manual when I noticed the problem. Here are the two systems info:
OS: Debian GNU/Linux 10 (buster)
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
Locale: C/Default (C)
AND:
OS: Debian GNU/Linux 10 (buster) (MATE/lightdm-xsession)
Version: 0.19.20325 (Git)
Hash: 7c9d5fe57c94eeec0289317e6be8a99bdceea11f
Python version: 3.7.3
Qt version: 5.11.3
When I run the example code:
import Draft
pl = FreeCAD.Placement()
pl.Rotation.Q = (0.0,0.0,0.0,1.0)
pl.Base = FreeCAD.Vector(-3.46933150291,0.713757812977,0.0)
rect = Draft.makeRectangle(length=4.00172472,height=-1.73174029589,placement=pl,face=True,support=None)
rect.MakeFace = True
rect.ViewObject.Pattern = "simple"
I do get the rectangle filled with the simple pattern in 0.18. If I save that file and try to view it in 0.19 I only get a solid grey filled one, no matter what pattern I try. If I then delete that one and run the python script again, I just get a plain empty rectangle, though the relevant properties are set correctly.
I only tried this on one computer, and I thought someone else might like to verify.
Thanks for a great project,
Clif
Reason: [FIXED]
Re: Draft Pattern problem
Moved to Python forum.
vocx
Post by vocx »
clifcox wrote: Tue Mar 31, 2020 5:24 am sorry for reopening this old thread,
You can open your own thread. You don't have to open a several years old thread.
I do get the rectangle filled with the simple pattern in 0.18. If I save that file and try to view it in 0.19 I only get a solid grey filled one, no matter what pattern I try...
Yes, patterns broke at some point, and nobody knows why. I don't know if it was during the LinkMerge or what but it happened.
The error message seems to come from Coin (pivy), as if the necessary method "removeChild" was removed in a new version of Coin. Or maybe Draft's code was changed.
  File "/opt/freecad-build-debug-vocx/Mod/Draft/Draft.py", line 3240, in onChanged
    r.removeChild(self.texture)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 4746, in __getattr__
    raise e
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 4738, in __getattr__
    return SoBase.__getattribute__(self, name)
<class 'AttributeError'>: 'SoPolygonOffset' object has no attribute 'removeChild'
clifcox
Post by clifcox »
Ok cool,
I'm trying to follow the recommended bug tracker workflow. Has this bug been submitted yet, or would you like me to do that?
Best,
Clif
Post by Kunda1 »
issue #4301: Draft Pattern problem ticket was opened and associated with this thread
Re: Ticket #4301 - Draft Pattern problem (upstream coin3d API change)
Post by Kunda1 »
Note: Thread was split off older thread https://forum.freecadweb.org/viewtopic.php?f=22&t=17628
Roy_043
Post by Roy_043 »
A bit of investigating:
  1. Open a new document
  2. Draw a rectangle
  3. Run test code below
  4. Compare V0.18 and V0.19 results
Conclusion:
In V0.18 vobj.RootNode.getChild(2).getChild(0).getChild(2) is a SoSeparator.
In V0.19 it is a SoPolygonOffset.
Creating a work-around is relatively easy.
view_base.py:
                                    r = vobj.RootNode.getChild(2).getChild(0).getChild(2)     # line 290
                                    if type(r) == coin.SoPolygonOffset:                       # workaround
                                        r = vobj.RootNode.getChild(2).getChild(0).getChild(3) # workaround
Test code:
vobj = Gui.ActiveDocument.Rectangle
print(vobj.RootNode.getChild(2).getChild(0).getChild(0))
print(vobj.RootNode.getChild(2).getChild(0).getChild(1))
print(vobj.RootNode.getChild(2).getChild(0).getChild(2))
print(vobj.RootNode.getChild(2).getChild(0).getChild(3))
Result V0.18:
<pivy.coin.SoSeparator; proxy of <Swig Object of type 'SoSeparator *' at 0x062EEC08> >
<pivy.coin.SoPolygonOffset; proxy of <Swig Object of type 'SoPolygonOffset *' at 0x062EECC8> >
<pivy.coin.SoSeparator; proxy of <Swig Object of type 'SoSeparator *' at 0x062EECC8> >
<pivy.coin.SoSeparator; proxy of <Swig Object of type 'SoSeparator *' at 0x062EEA58> >
Result V0.19:
<pivy.coin.SoSeparator; proxy of <Swig Object of type 'SoSeparator *' at 0x000000B12D50F480> >
<pivy.coin.SoPolygonOffset; proxy of <Swig Object of type 'SoPolygonOffset *' at 0x000000B12D50F480> >
Re: [FIXED] Ticket #4301 - Draft Pattern problem (upstream coin3d API change)
Post by Kunda1 »
Associated the commit to the ticket on Mantis. Change this thread to [fixed]
