Error when importing Arch module
peterl94
Postby peterl94 » Wed Jan 22, 2014 1:02 am
I was testing my mac build and I discovered that I couldn't import the Arch module in FreeCADCmd. It works fine in the gui.
>>> import Arch
  File "<stdin>", line 1, in <module>
  File "C:\Users\Peter\FreeCAD\FreeCAD_0.14\Mod\Arch\Arch.py", line 30, in <module>
    FreeCADGui.updateLocale()
AttributeError: 'module' object has no attribute 'updateLocale'
Does anyone else have this problem?
jmaustpc
Re: Error when importing Arch module
Postby jmaustpc » Wed Jan 22, 2014 3:50 am
Hi Peter
I get exactly the same here with this build on Linux
OS: Ubuntu 12.04.4 LTS
Platform: 64-bit
Version: 0.14.3052 (Git)
Hash: 88ff8076cdbcca2a52c13f40d1cb14df220b3c55
Python version: 2.7.3
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.0
Jim
jriegel
Site Admin
Postby jriegel » Wed Jan 22, 2014 8:05 am
Thats because Arch is dependent on the Gui. There fore its not usable in the command line and server version of FreeCAD. That means also you can not load a project which include Arch objects in FreeCADCmd.exe.
I'm not sure Yorik did that on purpose or it just happened.
Stop whining - start coding!
jmaustpc
Postby jmaustpc » Wed Jan 22, 2014 12:44 pm
You need the gui to export stl files so I was wonder if it is because its going to use meshes a bit and at least some mesh stuff requires the GUI?
yorik
Site Admin
Postby yorik » Wed Jan 22, 2014 12:44 pm
Actually it might be considered a bug... Indeed I never really adapted the Arch module to work without GUI yet :oops: I'll fix this ASAP. issue #1362
peterl94
Postby peterl94 » Wed Jan 22, 2014 5:05 pm
Okay, I just wanted to make sure it wasn't a problem with my build.
rockn
Postby rockn » Thu Jul 17, 2014 6:53 pm
Is Arch always able to work without Gui ?
I try to run a script with Arch.makeStructure() on a server. FreeCAD is compiled without Gui.
I get this :
web1@woodserver:~/web/FreeCADWeb/examples/kit$ FreeCADCmd
FreeCAD 0.14, Libs: 0.14R3727 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import Arch
>>> App.newDocument()
<Document object at 0x145d3f0>
  File "/usr/local/Mod/Arch/ArchStructure.py", line 298, in makeStructure
    _ViewProviderStructure(obj.ViewObject)
  File "/usr/local/Mod/Arch/ArchStructure.py", line 654, in __init__
    ArchComponent.ViewProviderComponent.__init__(self,vobj)
  File "/usr/local/Mod/Arch/ArchComponent.py", line 622, in __init__
    vobj.Proxy = self
AttributeError: 'NoneType' object has no attribute 'Proxy'
Do I forget something?
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
yorik
Site Admin
Postby yorik » Thu Jul 17, 2014 8:50 pm
Ah indeed I never really tested the Arch module in console mode... Good opportunity! I'll have a look at that.
rockn
Postby rockn » Thu Jul 17, 2014 10:02 pm
At the moment I have commented all reference to ViewProvider directly in the sources (makeStructure, makeStructuralSystem, WorkingPlane, makeAxis ...). It is working good (I can create a Structure and export it in webgl, it's just that all object are grey).
yorik
Site Admin
Postby yorik » Thu Jul 17, 2014 11:01 pm
Ok this should be all fixed now!
