jo@woodserver:~$ FreeCADCmd
FreeCAD 0.15, Libs: 0.15R3792 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import Draft
>>> import Drawing
>>> import Part
>>> import importDXF
DXF libraries not found. Downloading...
downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfColorMap.py ...
downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfImportObjects.py ...
downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfLibrary.py ...
downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfReader.py ...
File "<stdin>", line 1, in <module>
File "/usr/local/Mod/Draft/importDXF.py", line 1849, in <module>
dxfDefaultColor = getColor()
File "/usr/local/Mod/Draft/importDXF.py", line 277, in getColor
c = params.GetUnsigned("DefaultShapeLineColor",0)
NameError: global name 'params' is not defined
>>> exit()
FreeCADCmd
>>> import Arch
File "/usr/local/Mod/Arch/Arch.py", line 39, in <module>
from ArchSectionPlane import *
File "/usr/local/Mod/Arch/ArchSectionPlane.py", line 24, in <module>
import FreeCAD,WorkingPlane,math,Draft,ArchCommands,DraftVecUtils
File "/usr/local/Mod/Draft/WorkingPlane.py", line 25, in <module>
import FreeCAD, FreeCADGui, math, DraftVecUtils
ImportError: No module named FreeCADGui
File "/usr/local/Mod/Arch/ArchStructure.py", line 303, in makeStructure
obj.Base.ViewObject.hide()
AttributeError: 'NoneType' object has no attribute 'hide'
dim = Draft.makeDimension(App.Vector(curseur, 0.0, 0.0),App.Vector(curseur + i, 0.0, 0.0),App.Vector(0.0, -200.0, 0.0))
File "/usr/local/Mod/Draft/Draft.py", line 685, in makeDimension
normal = App.Vector(0,0,1)
NameError: global name 'App' is not defined
annoTxt = Draft.makeText(i,point=App.Vector(pergolaLongueur + 2200 + pergolaHauteur, pergolaLargeur + 800 + pergolaHauteur-curseur,0.0))
File "/usr/local/Mod/Draft/Draft.py", line 893, in makeText
if not screen: obj.ViewObject.DisplayMode="World"
AttributeError: 'NoneType' object has no attribute 'DisplayMode'
FreeCADCmd
>>> App.newDocument("Sans nom")
<Document object at 0x2480c50>
>>> App.setActiveDocument("Sans_nom")
>>> doc = App.ActiveDocument
>>> import Arch
>>> Arch.makeStructure(length=1000.0, width=100.0, height=100.0, name="Poutre")
<FeaturePython object at 0x2b37868>
>>> doc.recompute()
make ordering:
Poutre dep on: Recompute
Solv: Executing Feature: Poutre
>>> doc.saveAs(str("Test.fcstd"))
Thank you Yorik !yorik wrote:Okay all these issues should be fixed now...
buildWithOutGUI/bin$ ./FreeCADCmd
FreeCAD 0.15, Libs: 0.15R3817 (Git)
>>> import Draft
>>> import Arch
<Document object at 0x22cb800>
>>> App.ActiveDocument=App.getDocument("Sans_nom")
>>> import Draft
>>> Draft.makeDimension(FreeCAD.Vector(-0.0912128388882,0.225349321961,0.0),FreeCAD.Vector(2.41445708275,0.300465762615,0.0),FreeCAD.Vector(2.31251335144,0.858473658562,0.0))
File "/home/jo/Logiciels/FreeCAD/free-cad-code/buildWithOutGUI/Mod/Draft/Draft.py", line 3001, in onChanged
obj.setEditorMode('Distance',1)
<type 'exceptions.AttributeError'>: Property container has no property 'Distance'
<Document object>
>>> App.getDocument("Sans_nom").saveAs('/home/jo/Documents/FreeCAD/Cote.fcstd')
>>> doc = FreeCAD.newDocument()
>>> FreeCAD.ActiveDocument
<Document object at 0xfa8b10>
>>> obj = doc.addObject("App::FeaturePython","Test")
>>> obj
<FeaturePython object at 0x10557e8>
>>> obj.ViewObject
AttributeError: 'module' object has no attribute 'getDocument'
