[PR Merged] Ticket #4575 - [Solved with workaround] Window/Door holes incorrect - again
Re: Ticket #4575 - [Solved with workaround] Window/Door holes incorrect - again
Post by Kunda1 »
@paullee issue #6165 is still open
paullee
Post by paullee »
Kunda1 wrote: Tue Sep 13, 2022 12:56 pm @paullee issue #6165 is still open
Yes, the PR submitted is yet to be merged, should fix the problem as tested :)
Post by Kunda1 »
PR is not linked to the ticket, is it ?
paullee
Post by paullee »
Kunda1 wrote: Thu Sep 22, 2022 8:49 am PR is not linked to the ticket, is it ?
https://github.com/FreeCAD/FreeCAD/pull/6617
Seems not
Post by Kunda1 »
bump
AndrewA
Post by AndrewA »
Apologies, I finished the project, Self Build, I had on FreeCAD, and have not really looked at it since. Unfortunately, I do not have time to build from a PR at the moment. When I've finished the build I'll probably dabble with FreeCAD again.
paullee
[PR Merged] Re: Ticket #4575 - [Solved with workaround] Window/Door holes incorrect - again
Post by paullee »
AndrewA wrote: Mon Nov 21, 2022 8:01 pm Apologies, I finished the project, Self Build, I had on FreeCAD, and have not really looked at it since. Unfortunately, I do not have time to build from a PR at the moment. When I've finished the build I'll probably dabble with FreeCAD again.
PR Merged in other thread - viewtopic.php?p=660136#p660136
@AndrewA Please test and marked 'Fixed' in 1st post title if +ve, thanks :)
