bitacovir wrote: ↑Sun May 02, 2021 2:14 pm
Roy_043 wrote: ↑Sun May 02, 2021 8:45 am
Hmm, this is more complex. If you start with the Draft WB the "A, R" shortcut actually does not work. You have to load the BIM WB first.
The issue seems to be related to toolbuttons on flyouts.
The menu nesting does not seem to cause it. F.e.: if you start with the Arch WB the "C, I" shortcut works fine even though the tool sits in a nested menu.
What happen if you don't have BIM WB installed?
All shortcuts work as intended from Arch, Draft or Bim installed or not on my machine. Windows 8.1 reach Mainstream End of Life Jan 8th 2018. Could contribute to problems in these newer FreeCAD releases.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
