[ Bug ] "Show Fill" in ArchView-TechDraw no longer works
paullee
Postby paullee » Wed Apr 07, 2021 9:27 pm
It seems Show Fill set to True no longer works for ArchWall in TechDraw with ArchView :)
Tested with below AppImages on Fedora 31
Not Working
FreeCAD_0.19-24276-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD_0.19-23756-Linux-Conda_glibc2.12-x86_64.AppImage
Working
FreeCAD_0.19-23578-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD_0.19-23258-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD_0.19-21775-Linux-Conda_glibc2.12-x86_64.AppImage
Screenshot from 2021-04-08 05-11-58.png (229.35 KiB) Viewed 323 times
Screenshot from 2021-04-08 05-12-02.png (261.34 KiB) Viewed 323 times
OS: Fedora 31 (Workstation Edition) (GNOME/gnome)
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Version: 0.19.23756 (Git) AppImage
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Version: 0.19.23578 (Git) AppImage
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Qt version: 5.12.5
OCC version: 7.4.0
bitacovir
Re: [ Bug ] "Show Fill" in ArchView-TechDraw no longer works
Postby bitacovir » Wed Apr 07, 2021 10:31 pm
I confirm with FC 0.20 in windows
OS: Windows 10 Version 1909
Version: 0.20.24587 (Git)
Hash: 1f62d4666102d8efd4d8f3ba58a1037456a3bcfb
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
Syres
Postby Syres » Thu Apr 08, 2021 9:32 am
The commit that appears to have caused the regression is git commit d7692e3 so I think @yorik would need to be involved in a fix so what he was trying to achieve isn't re-broken!! Copying the old ArchSectionPlane.py over the new one worked for me, what confused me on testing was that when I opened your file ArchView was set to Wireframe and not Solid.
bitacovir
Postby bitacovir » Thu Apr 08, 2021 12:34 pm
I left a message in the commit linking to this thread. If Yorik is too busy we just could leave a report in the bugtracker.
::bitacovir::
My old Blog
Syres
Postby Syres » Thu Apr 08, 2021 1:29 pm
All I did was change line 456 of src\Mod\Arch\ArchSectionPlane.py from:
            svgcache += render.getSectionSVG(linewidth="SVGCUTLINEWIDTH",fillpattern="#ffffff")
which is pure white (and so looks like it's not working but it is really) to:
            svgcache += render.getSectionSVG(linewidth="SVGCUTLINEWIDTH",fillpattern="#d6d6d6")
which is the same as 'sectionfill' but I suppose unless we know what the exact fault was that caused the change then we won't know if a PR is worth raising.
paullee
Postby paullee » Thu Apr 08, 2021 2:46 pm
Probably @Yorik want to achieve to use colour of the object for the fill colour (announced somewhere and probably in wikj) he did the change ?
And Solid is kind of buggy to my memory as @Yorik explained.
On the move, see what we can do later.
Probably ping him or leave a bug report :D
paullee
Postby paullee » Thu Apr 08, 2021 2:49 pm
p.s.
Now it make sense -
So if the Wall / Object colour is white (or same colour as TechDraw background) i.e. White, it should default to say Gray, otherwise the current regression.
paullee
Postby paullee » Thu Apr 08, 2021 11:54 pm
Without attempt to check the code :), I do further test:-
  1. A Material is created with name of 'Concrete'
  2. Color is Red, Section Colour is Blue
  3. Assign to the Wall object
  4. Workaround some Recompute bugs (e.g. needs turn on Fuse Arch, and turn it off to trigger 'real compute')
  5. Now ArchView show Section Colour :D
Screenshot from 2021-04-09 07-38-37.png (273.88 KiB) Viewed 120 times
Screenshot from 2021-04-09 07-38-56.png (278.78 KiB) Viewed 120 times
Screenshot from 2021-04-09 07-39-04.png (268.1 KiB) Viewed 120 times
Screenshot from 2021-04-09 07-40-11.png (264.43 KiB) Viewed 120 times
