I fixed making blocks on a sketch based wall. Please take a look at patch #1 and #2.
The problem occurs because execute() expects self.basewires to contain a list of Wire, while fro sketch based walls getExtrusionData() sets self.basewires to a list of list of Edge.
EDIT:
There is #3 which to me seems the right solution.
[BUG] Cannot make blocks on a sketch based wall
Re: [BUG] Cannot make blocks on a sketch based wall
Probably I had created this regressionsteelman wrote: ↑Mon Apr 19, 2021 11:10 am I fixed making blocks on a sketch based wall. Please take a look at patch #1 and #2.
EDIT:
I have a glance and probably # 1 with below may solve the problem. Other will create further regressions to create Wall based on (Complex) Sketch
if isinstance(self.basewires[0],Part.Wire):
elif isinstance(self.basewires[0],Part.Edge):
Hmm, I probably misunderstand, but I do not have an issue with the "Make Blocks" property of a sketch based wall.
Version: 0.20.24587 (Git)
Hash: 1f62d4666102d8efd4d8f3ba58a1037456a3bcfb
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
- sketch-based-wall-blocks.FCStd
- (70.02 KiB) Downloaded 23 times
Right, any sketch with more than one edge, even an open loop, will result in this bug.
Note that solution #3 does not work for open loops. I have not tested the other solutions
Also the problem is perhaps a bit more complex. See the attachments (created after implementing solution #3).
- sketch-based-wall-blocks-2.png (11.96 KiB) Viewed 643 times
- sketch-based-wall-blocks-2.FCStd
- (106.92 KiB) Downloaded 20 times
You mean the corner piece is not correct? I thought it used to be like that?Roy_043 wrote: ↑Tue Apr 20, 2021 2:10 pm Right, any sketch with more than one edge, even an open loop, will result in this bug.
EDIT
p.s.
I can create horizontal joint, but not vertical joint.
OS: Fedora 31 (Workstation Edition) (GNOME/gnome)
Version: 0.19.23756 (Git)
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Qt version: 5.12.5
OCC version: 7.4.0
"Make Blocks" was introduced in V0.18. And both that version and V0.19 have this bug. But there may have been a V0.19 pre version where it did not occur.
Edit: Note that this bug does not occur if the base of the wall is a Draft_Wire or a Draft_Rectangle.
