Point input
- I think it would make sense to always allow polar coordinates.
- The "Enter point" button appears above the angle and length fields. This suggests that this button should not be used when entering polar coordinates.
- Point input for some commands is non-standard: Draft_ShapeString f.e.
- In the case of some array commands clicking a point will finish the command. This is also non-standard behavior.
- Undo button has no purpose. Also reported here: https://forum.freecadweb.org/viewtopic.php?f=23&t=57307 Fixed #5223.
- Relative toggle has no purpose. Fixed #5223.
- Wrong title and icon ("Point"). Fixed #5250.
- Continue toggle missing. Fixed #5250.
- Wrong title and icon ("Arc"). Fixed.
- Filled toggle missing (since V0.19). Fixed.
- Continue toggle missing on the first task panel. Fixed #5223.
- Cannot use the "T" shortcut for the Continue toggle on the second task panel. Fixed #5223.
- The Label Type dropdown list does not contain all available options. "Label + Position" - "Label + Material" are missing. Fixed #5249.
- 'Modify subelements' setting is not stored.
- Relative toggle has no purpose. Fixed #5384.
- Continue toggle is ignored. Continue mode is unlikely for this command. Toggle removed #5384.
- Copy toggle on the 1st task panel is ignored. Removed #5384.
- 'Modify subelements' toggle on the 1st task panel is ignored although the preview suggests otherwise. Interestingly the opposite applies for the toggle on the 2nd task panel: wrong preview, but correct result. Toggle removed from 1st task panel, preview now updates when switching to or from subelement mode (for other modifier command as well) #5384.
- 'Create a clone' toggle should also be available on the 1st task panel. No longer an issue: all toggles except the Global toggle were removed from the 1st task panel #5384.
- 2nd task panel has a wrong icon. Fixed #5384.
- Toggles on the 2nd task panel do not have shortcuts. No longer an issue: all toggles except the Global toggle were removed from the 1st task panel #5384.
- Checking the 'Uniform scaling' toggle does not make the existing X, Y and Z factors equal. You have to change one of them first. Fixed #5384.
- 'Working plane orientation' toggle should perhaps be changed to 'Global scale orientation'. This would be more logical as there is a Global toggle on the first task panel.
- 'Modify subelements' and 'Create a clone' can both be checked, but that combination makes no sense. Fixed #5384.
- 'Modify subelements' and 'Copy' cannot be combined. This is possible however for Draft_Move and Draft_Rotate. Fixed #5282 (previous PR).
- Continue toggle should also be available on the 2nd task panel. No longer an issue: toggle removed from the 1st task panel #5384.
- Number of decimals for the coordinates of the point is determined by Edit > Preferences > General > Units > Number of decimals. Number of decimals for the scale factors is determined by Edit > Preferences > Draft > Internal precision level. Fixed #5384.
- The Close button on the 1st task panel has the same function as the Cancel button on the 2nd panel.
- Continue toggle has no purpose. Fixed #5384.
- 'Modify subelements' toggle has no purpose. Fixed #5384.
- Filled toggle has no purpose. Fixed #5384.
- The 2nd Close button (with the icon) on the 1st task panel is strange. It only works if a single Draft Wire is selected. Fixed #7527.
- The 2nd task panel (displayed if a node is moved) has a wrong title and icon ("Line"). Fixed #7527.
- Relative toggle on the 2nd task panel has no purpose. Fixed #7541.
- Continue toggle on the 2nd task panel has no purpose. Fixed #7541.
- Undo button on the 2nd task panel has no purpose. Fixed #5223.
Version: 0.20.24893 (Git)
Hash: 03855f793feaceeb4385c02f6520f3e1b6429c93
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
