[Working Macro][work in progress] Curved Path Stairs
Re: Curved Path Stairs
So cool!
Thank you
That would be really great all help is welcome Things that need to be done are:
- make a parametric Arch stair out of this macro(I do not have any experience with this, so I could use help/advice)
- make a railing that would follow the stairs(also with rods)
- later also to have an icon for the command(it would be best to have several different stair commands, similar to rebar commands)
- when all is done, to have it all in wiki
Also for the stairs, I did not have so much time to work on them, but... they are looking good They are actually mostly done, except that I dont know if I can fuse them nicely and refine them(at the moment each step is a separate object). Below are some cool pics and the code.
You generate the stairs by selecting each edge on a path(in a logical way) The edges you select can only turn in one direction for now, so you can make L or U stairs. With this code, you need to use a closed wire for the stairs, just select a path on this wire.
- Pasted Layer.png (238.94 KiB) Viewed 2680 times
- Pasted Layer #4.png (251.24 KiB) Viewed 2680 times
- Pasted Layer #3.png (220.44 KiB) Viewed 2680 times
- Pasted Layer #2.png (277.55 KiB) Viewed 2680 times
- New Stairs6.FCMacro
- (2.91 KiB) Downloaded 66 times
Very impressive work!!!
Maybe I could help with the first point, but first I think it is necessary to refine the steps by merging them into a single object.....and later I'd be happy to help you with such implementation if you agree.ABeton wrote: ↑Thu May 06, 2021 8:10 pm That would be really great all help is welcome Things that need to be done are:
Is there something you would like to do?
I merged and refined the steps, unfortunatley computation times are not the best and there are a couple of problems I need to solve, it takes at least 15 sec to generate them, but still it is not bad If you could help me with the first point that would be great, how did you think to do it? Just a short description to get an idea
Also great work on the main stair tool(I saw it in the other thread), I hope it gets implemented soon!
Hi ABeton,
I think your work could easily become a FreeCad parametric object.....to turn it into an object just follow the pattern of the "python feature" (for more details see here)
In brief:
- Define a class (in this case, it could be called "CurvedPathStairs"), where it will possible implement this object, which mostly you have already defined in your macro.
- Create a view provider class (e.g. "ViewProviderCurvedPathStairs") which defines how the object will be displayed.
In this manner, the object will be totally parametric.
Thank you and look forward to seeing your progress.
Thank you for the advice three_d and sorry for the late response. There are some annoying bugs I have been trying to squash I will simplify the tool to work with only closed wires selected(first I wanted to do any kind of wire, but it is not practical).
I checked the link you attached and I get it how it works in principle, when I finish with the bugs I will move on to make it parametric. I have an idea how to add railing later, but I am a little lazy to do it
I think that for FreeCAD to get more traction as real architecture software we need to solve the problem of making 2D drawings. This is a bit off topic, but now I see it should be our priority numero uno. I will finish the stairs first, then the modifications I started doing to the object library, and then all of us interested in architecture on this forum should see how to make 2D more user friendly for architects. At least to make a more detailed plan other people can reference later and understand how things should be done.
Good plan @Abeton
Thanks @paullee. Maybe we should have a thread in the forum dedicated just to 2D for architecture. There we could have a propper discussion about 2D, to see in what way we could make it work. At least to create a plan of action for starters, and to describe it all in detail.
Also we could gather links of old discussions there to have them as a reference. What do you think?
