[Working Macro][work in progress] Curved Path Stairs
ABeton
Post by ABeton »
Curved Path Stairs
A new way to create parametric stairs which would be created from a path and a closed sketch.
How it works:
User creates a closed sketch(in a logical way) and selects the path lines on this sketch. Stairs are generated according to the path and would have the shape of the closed sketch.The macro is works now, but needs to be polished and needs a GUI.
Notes:
  • when drawing a stair path it is important that you draw lines from start to finish of the stairs
  • stairs are created from closed wires(either sketch or draft)
  • there is an "align" option in the macro if you get some errors when creating the stairs just change the value and see if it works. Options are "left" and "right"
Previous detailed discussion here: https://forum.freecadweb.org/viewtopic.php?f=22&t=58023
Curved Path Stairs (no GUI).FCMacro
(5.14 KiB) Downloaded 79 times
paullee
Re: Curved Path Stairs
Post by paullee »
That's really cool !
I wish the ideas of different 'types' of stairs as discussed could be further refined and implemented, so a uniform codes in modular approach could be made for further extendibility :)
bitacovir
Post by bitacovir »
Cool!
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
ABeton
Post by ABeton »
I think we can do it, first to make working stair algorithms and than to incorporate them into the stair tools. I saw in Revit that they have a stair button and when you click it opens several diferent buttons which all make stairs in different ways. Something similar we have with Aray tools in the Draft workbench where they are all grouped under one Array button.
paullee
Post by paullee »
Great! Hope can get back to this party when there is a gap :D
ABeton
Post by ABeton »
Yeahh I hope so too, more people working on Arch is always better :D
I was hunting for a piece of code that would make it possible to make stairs out of wires with both straight and curved lines and I found it.... in the path_array file in Draft of course :lol: There they used "getParameterByLength" which as the name says returns the main parameter used by an element based on the length you select on that element. So for a straight line it returns the length, for an arc it returns the angle and so on.
Anyway, the code mostly works now to create stair edges(although with bugs). Just select the path edges(it is necessary to select them in the correct order), and it should work.
Also I wanted to ping onekk, but I do not know how to ping :oops:
Pasted Layer #1.png (269.92 KiB) Viewed 4191 times
Pasted Layer #2.png (273.09 KiB) Viewed 4191 times
New Stairs5.FCMacro
(2.02 KiB) Downloaded 74 times
paullee
Post by paullee »
ABeton wrote: Sun May 02, 2021 8:52 pm Ping
For example :)
[quote=onekk user_id=5245]
Ping
[/quote]
ABeton
Post by ABeton »
paullee wrote: Tue May 04, 2021 1:20 pm
For example :)
Ping
[/quote]
Ahh ok, thank you :D
three_d
Post by three_d »
Wow, this is awesome!
paullee wrote: Sun May 02, 2021 5:18 pm I wish the ideas of different 'types' of stairs as discussed could be further refined and implemented, so a uniform codes in modular approach could be made for further extendibility
ABeton wrote: Sun May 02, 2021 8:52 pm I think we can do it, first to make working stair algorithms and than to incorporate them into the stair tools.......
Totally agree!
ABeton
Post by ABeton »
Thanks three_d :) If you have any ideas/suggestions feel free to chip in.
