[ Fixed ] [ Bug ] Draft_SetStyle failed: no attribute 'dimButton'
Roy_043
Post by Roy_043 »
Pretty recent stuff:
Calling Draft_SetStyle results in an error:
Running the Python command 'Draft_SetStyle' failed:
File "D:\BKG_Tmp\FreeCAD_0.20_Last\Mod\Draft\draftguitools\gui_setstyle.py", line 61, in Activated
FreeCADGui.Control.showDialog(Draft_SetStyle_TaskPanel())
File "D:\BKG_Tmp\FreeCAD_0.20_Last\Mod\Draft\draftguitools\gui_setstyle.py", line 76, in __init__
self.form.dimButton.setIcon(QtGui.QIcon(":/icons/Draft_Text.svg"))
'PySide2.QtWidgets.QWidget' object has no attribute 'dimButton'
OS: Windows 8.1 Version 6.3 (Build 9600)
Version: 0.20.24893 (Git)
Hash: 03855f793feaceeb4385c02f6520f3e1b6429c93
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
bitacovir
Re: [ Bug ] Draft_SetStyle failed: no attribute 'dimButton'
Post by bitacovir »
Roy_043 wrote: Mon May 17, 2021 10:46 am Pretty recent stuff:
It works for me if I load Draft WB first
OS: Windows 10 (10.0)
Version: 0.20.24894 (Git)
Hash: a378b6b66f8a5992fc1452567ff59bdb613abc80
Python version: 3.8.10
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Roy_043
Post by Roy_043 »
bitacovir wrote: Mon May 17, 2021 11:27 am It works for me if I load Draft WB first
Of course I also do that.
Updating to your version resolves the issue. Strange...
Roy_043
Post by Roy_043 »
Apparently the problem is not related to the FreeCAD version, but rather related the Qt version?
The problem occurs in this version:
Version: 0.20.24986 (Git)
Hash: ff6845e2f31988cc714027980e0100bb5521843e
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Post by yorik »
Everything seems to work OK here... Do you compile FreeCAD yourself? You might need to touch Draft.qrc , that happens sometimes, an .ui file gets changed, but since the .qrc file didn't change, cmake doesn't recompile it
Roy_043
Post by Roy_043 »
yorik wrote: Tue Jun 01, 2021 3:22 pm Do you compile FreeCAD yourself?
No. The mentioned version is a weekly build:
FreeCAD_0.20.24986_Win-LPv12.5.4_vc17.x-x86-64.7z
Roy_043
Post by Roy_043 »
yorik wrote: Tue Jun 01, 2021 3:22 pm Everything seems to work OK here... Do you compile FreeCAD yourself? You might need to touch Draft.qrc , that happens sometimes, an .ui file gets changed, but since the .qrc file didn't change, cmake doesn't recompile it
It is probably a compile issue.
I am using these weekly builds ATM:
FreeCAD_0.20.25065_Win-LPv12.5.4_vc17.x-x86-64.7z
FreeCAD_weekly-builds-25065-Win-Conda_vc14.x-x86_64.7z
If I check the Draft_rc.py file I notice that only in the case of the Conda version does it contain a reference to "dimButton".
Syres
Post by Syres »
sgrogan wrote: Thu Mar 04, 2021 10:51 pm ping
Could you please have a look that this with regard to the compilation of the weekly LP build noting @Yorik's comment above?
Roy_043
Post by Roy_043 »
This bug has been fixed. Thanks.
FreeCAD_0.20.25306_Win-LPv12.5.4_vc17.x-x86-64.7z
Version: 0.20.25306 (Git)
Hash: 5f5b3d9b67136edda1f6738f1a83154990f7839d
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
uwestoehr
Post by uwestoehr »
How do I touch the Draft.qrc to force Cmake's recompilation?
I am asking because Roy_043 pointed me to this to resolve the bug I reported here:
https://tracker.freecadweb.org/view.php?id=4705
