[ Bug ] Draft_SetStyle failed: no attribute 'dimButton'
Roy_043
Postby Roy_043 » Mon May 17, 2021 10:46 am
Pretty recent stuff:
Calling Draft_SetStyle results in an error:
Running the Python command 'Draft_SetStyle' failed:
File "D:\BKG_Tmp\FreeCAD_0.20_Last\Mod\Draft\draftguitools\gui_setstyle.py", line 61, in Activated
FreeCADGui.Control.showDialog(Draft_SetStyle_TaskPanel())
File "D:\BKG_Tmp\FreeCAD_0.20_Last\Mod\Draft\draftguitools\gui_setstyle.py", line 76, in __init__
self.form.dimButton.setIcon(QtGui.QIcon(":/icons/Draft_Text.svg"))
'PySide2.QtWidgets.QWidget' object has no attribute 'dimButton'
Version: 0.20.24893 (Git)
Hash: 03855f793feaceeb4385c02f6520f3e1b6429c93
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
bitacovir
Re: [ Bug ] Draft_SetStyle failed: no attribute 'dimButton'
Postby bitacovir » Mon May 17, 2021 11:27 am
Roy_043 wrote: Mon May 17, 2021 10:46 am Pretty recent stuff:
It works for me if I load Draft WB first
OS: Windows 10 (10.0)
Version: 0.20.24894 (Git)
Hash: a378b6b66f8a5992fc1452567ff59bdb613abc80
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
Roy_043
Postby Roy_043 » Mon May 17, 2021 1:20 pm
bitacovir wrote: Mon May 17, 2021 11:27 am It works for me if I load Draft WB first
Of course I also do that.
Updating to your version resolves the issue. Strange...
Roy_043
Postby Roy_043 » Tue Jun 01, 2021 2:03 pm
Apparently the problem is not related to the FreeCAD version, but rather related the Qt version?
The problem occurs in this version:
Version: 0.20.24986 (Git)
Hash: ff6845e2f31988cc714027980e0100bb5521843e
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
yorik
Site Admin
Postby yorik » Tue Jun 01, 2021 3:22 pm
Everything seems to work OK here... Do you compile FreeCAD yourself? You might need to touch Draft.qrc , that happens sometimes, an .ui file gets changed, but since the .qrc file didn't change, cmake doesn't recompile it
Roy_043
Postby Roy_043 » Tue Jun 01, 2021 3:27 pm
yorik wrote: Tue Jun 01, 2021 3:22 pm Do you compile FreeCAD yourself?
No. The mentioned version is a weekly build:
FreeCAD_0.20.24986_Win-LPv12.5.4_vc17.x-x86-64.7z
Roy_043
Postby Roy_043 » Thu Jun 17, 2021 9:14 am
yorik wrote: Tue Jun 01, 2021 3:22 pm Everything seems to work OK here... Do you compile FreeCAD yourself? You might need to touch Draft.qrc , that happens sometimes, an .ui file gets changed, but since the .qrc file didn't change, cmake doesn't recompile it
It is probably a compile issue.
I am using these weekly builds ATM:
FreeCAD_0.20.25065_Win-LPv12.5.4_vc17.x-x86-64.7z
FreeCAD_weekly-builds-25065-Win-Conda_vc14.x-x86_64.7z
If I check the Draft_rc.py file I notice that only in the case of the Conda version does it contain a reference to "dimButton".
Syres
Postby Syres » Fri Jun 18, 2021 3:39 pm
sgrogan wrote: Thu Mar 04, 2021 10:51 pm ping
Could you please have a look that this with regard to the compilation of the weekly LP build noting @Yorik's comment above?
