[ Fixed ] Draft Shape2DView: Tessellation does not project straight edges
Roy_043
Post by Roy_043 »
If you change 'Tessellation' to 'true' for a Shape2DView, projected curves will be replaces by sequences of lines segments, as you would expect. But for some reason *only* the tessellated curves are then visible in the projection, all straight edges are missing.
Version: 0.20.24893 (Git)
Hash: 03855f793feaceeb4385c02f6520f3e1b6429c93
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Roy_043
Re: [ Fixed ] Draft Shape2DView: Tessellation does not project straight edges
Post by Roy_043 »
Merged.
