Apart from the obvious rotation that can be seen by focusing on the 'protrusion' of the object, I'd like to draw attention to the alignment of the middle element in the arrays. In V0.20 it is always the same. In V0.18 it is different for the array that is closest to the camera.
In V0.20 there is also an accuracy issue related to the placement of the 1st element in the 1st array (bottom left element of the leftmost array in the image).
tangent t=Vector (-4.996003610813204e-16, 3.3306690738754696e-16, 1.0)
normal n=Vector (0.0, 0.0, 1.0)
Effectively these vectors are parallel, calculating a binormal from them does not make sense, but the code does use this vector:
binormal b=Vector (0.554700196225229, 0.8320502943378436, -0.0)
The wires were created with this code.
import FreeCAD as App
import Draft
doc = App.ActiveDocument
# 'random' placement:
pl = App.Placement()
pl.Rotation.Q = (0.5252490575950084, 0.10516732714534528, 0.16578312893689348, 0.8279910717855314)
pl.Base = App.Vector(0.0, 0.0, 0.0)
points1 = [App.Vector(200.0, -100.0, -100.0),
App.Vector(200.0, -100.0, 100.0),
App.Vector(150.0, 100.0, 100.0),
App.Vector(100.0, 100.0, -100.0)]
points2 = [App.Vector(450.0, -100.0, -100.0),
App.Vector(450.0, -100.0, 100.0),
App.Vector(400.0, 100.0, 100.0),
App.Vector(350.0, 100.0, -100.0)]
points3 = [App.Vector(750.0, -100.0, -100.0),
App.Vector(700.0, -100.0, 100.0),
App.Vector(650.0, 100.0, 100.0),
App.Vector(600.0, 100.0, -100.0)]
wire1 = Draft.makeWire(points1, placement=pl)
wire2 = Draft.makeWire(points2)
wire3 = Draft.makeWire(points3)
doc.recompute()
OS: Windows 8.1 Version 6.3 (Build 9600)
Version: 0.20.24986 (Git)
Hash: ff6845e2f31988cc714027980e0100bb5521843e
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
