[ Inaccuracy Fixed ] Draft_PathArray: Align Mode Original does not match V0.18
Roy_043
Post by Roy_043 »
After some more testing I now notice that the so called "Original" "Alignment Mode" in V0.20 does not match the V0.18 behavior.
Apart from the obvious rotation that can be seen by focusing on the 'protrusion' of the object, I'd like to draw attention to the alignment of the middle element in the arrays. In V0.20 it is always the same. In V0.18 it is different for the array that is closest to the camera.
In V0.20 there is also an accuracy issue related to the placement of the 1st element in the 1st array (bottom left element of the leftmost array in the image).
tangent t=Vector (-4.996003610813204e-16, 3.3306690738754696e-16, 1.0)
normal n=Vector (0.0, 0.0, 1.0)
Effectively these vectors are parallel, calculating a binormal from them does not make sense, but the code does use this vector:
binormal b=Vector (0.554700196225229, 0.8320502943378436, -0.0)
The wires were created with this code.
import FreeCAD as App
import Draft
doc = App.ActiveDocument
# 'random' placement:
pl = App.Placement()
pl.Rotation.Q = (0.5252490575950084, 0.10516732714534528, 0.16578312893689348, 0.8279910717855314)
pl.Base = App.Vector(0.0, 0.0, 0.0)
points1 = [App.Vector(200.0, -100.0, -100.0),
           App.Vector(200.0, -100.0,  100.0),
           App.Vector(150.0,  100.0,  100.0),
           App.Vector(100.0,  100.0, -100.0)]
points2 = [App.Vector(450.0, -100.0, -100.0),
           App.Vector(450.0, -100.0,  100.0),
           App.Vector(400.0,  100.0,  100.0),
           App.Vector(350.0,  100.0, -100.0)]
points3 = [App.Vector(750.0, -100.0, -100.0),
           App.Vector(700.0, -100.0,  100.0),
           App.Vector(650.0,  100.0,  100.0),
           App.Vector(600.0,  100.0, -100.0)]
wire1 = Draft.makeWire(points1, placement=pl)
wire2 = Draft.makeWire(points2)
wire3 = Draft.makeWire(points3)
doc.recompute()
Version: 0.20.24986 (Git)
Hash: ff6845e2f31988cc714027980e0100bb5521843e
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Draft_PathArray-accuray-v020.FCStd
(28.74 KiB) Downloaded 43 times
Draft_PathArray-accuray-v018.FCStd
(35.33 KiB) Downloaded 42 times
Roy_043
Re: [ Bug ] Draft_PathArray: Align Mode Original does not match V0.18
Post by Roy_043 »
The inaccuracy issue was fixed with this PR:
https://github.com/FreeCAD/FreeCAD/pull/7506
Align Mode Original in V0.18 works differently because multiple segments are considered. This is no longer the case in the V0.20 code. Reverting that would not be good idea.
