I am looking for the Draft_Edit key combinations valid for macOS so that they can be added to the documentation. If you are a Mac user: please help! Thanks.
Instructions how to use the command:
https://forum.freecadweb.org/viewtopic. ... 56#p490019
Note that for the E key to work you have to click in the 3D view once to ensure that it has the focus.
Linux key combinations: Shift+Alt+LMB, Ctrl+Alt+LMB or E.
https://forum.freecadweb.org/viewtopic. ... 85#p493719
https://forum.freecadweb.org/viewtopic. ... 81#p399023
Windows key combinations: Alt+LMB or E.
https://forum.freecadweb.org/viewtopic. ... 85#p493901
Draft_Edit: key combinations for macOS?
Re: Draft_Edit: key combinations for macOS?
Alt is called Option on macOS so
Option+LeftMouse on a line ->add point
Option+LeftMouse on a vertex ->delete point
Note: Delete point works here, add point does nothing
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
Sorry, I am using Draft not very often (for drafting) and even less often for editing, so I had to learn what the E key does.
The following procedure works here:
- Select a Wire
- Click the Edit icon
- Place the mouse over an edge
- Hit the E key -> a popup bubble "Add point" occurs,
- Select "Add points" will insert a new point.
So in your experience add points works only if the context menu was activated via the "E" Key? If you use It with Option+LMB It doesn't work?
Exactly. I admit that I still have the feeling I have forgotten something or made something stupid. This is what doesn't work:
- Select a Wire
- Option+LMB -> a popup bubble "Add point" occurs as before
- Select "Add points" (either by mouse or keyboard, which both work in the case above) does nothing except closing the popup bubble.
Hmmm strange... No idea what could be the difference between the 2 workflows...
If you have any idea, just ping me. Glad to help.
Ok. Thanks Chris!
