Bug: Draft Offset and keyboard shortcuts
AKielhorn
Post by AKielhorn »
I discovered an inconsistency with the Offset command.
When I select an object and call the Offset command I have the option to select p to create a copy.
But when I do this, the p is inserted as a value in the Distance field. I have to delete the p to enter a value.
In addition to that, it the p only works when the focus is in the Distance field.
When I do the same in the Move command, everything works as expected.
I'm using:
OS: macOS High Sierra (10.13)
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.9.2
Qt version: 5.12.9
OCC version: 7.5.1
Locale: C/Default (C)
Roy_043
Re: Bug: Draft Offset and keyboard shortcuts
Post by Roy_043 »
Confirmed.
Version: 0.20.24986 (Git)
Hash: ff6845e2f31988cc714027980e0100bb5521843e
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I can confirm this, perhaps it is a MacOS only issue. There are already some topics about shortcuts where you may find additional information.
OS: macOS 10.16
Version: 0.20.24825 (Git)
Hash: ccc4151b3020969450325466e385850783795325
Qt version: 5.12.9
OCC version: 7.5.1
Roy_043
Post by Roy_043 »
chrisb wrote: Sat Jun 12, 2021 9:49 am perhaps it is a MacOS only issue
Obviously not.
chrisb wrote: Sat Jun 12, 2021 9:49 am There are already some topics about shortcuts
These are very specific shortcuts. Related to the task panel and not the menu or toolbars.
marioalexis
Post by marioalexis »
AKielhorn
Post by AKielhorn »
This is fixed in nightly build 25131.
Thanks.
