[ Fixed ] [ Bug ] Draft_PathArray edge selection order problem
Roy_043
Post by Roy_043 »
For a Draft_PathArray it is possible to select edges for the path. They must belong to the same object, they must be connected, and they must be selected in the correct order. The last restriction is a bug IMO.
Selection order:
BL: Edge1, Edge2, Edge3, Edge4. Correct order.
TL: Edge1, Edge4, Edge3, Edge2.
BR: Edge4, Edge1. Correct order.
TR: Edge1, Edge4.
Version: 0.20.24986 (Git)
Hash: ff6845e2f31988cc714027980e0100bb5521843e
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Draft_PathArray-edge-selection-order-problem.FCStd
(20.4 KiB) Downloaded 39 times
Roy_043
Re: [ Bug ] Draft_PathArray edge selection order problem
Post by Roy_043 »
This is probably not that hard to solve. But I wonder what would be the 'standard' Draft approach to address such an issue? Where do you validate user input:
...\Mod\Draft\draftguitools\gui_patharray.py
...\Mod\Draft\draftobjects\patharray.py
Roy_043
Post by Roy_043 »
https://github.com/FreeCAD/FreeCAD/pull/4899
The PR only fixes the issue, but does not address the validation of user input.
Roy_043
Post by Roy_043 »
Merged.
Re: [ Fixed ] [ Bug ] Draft_PathArray edge selection order problem
Post by Kunda1 »
Thank you!
