The 3D view context menu available while creating a Draft_Wire in the Draft WB still shows 3 obsolete commands:
Draft_UndoLine
Draft_FinishLine
Draft_CloseLine
These options are not avialable if the Arch WB is active.
[ Fixed ] Draft: Obsolete wire tools still in context menu
- Draft-wire-context-menu.png (6.53 KiB) Viewed 1642 times
Re: [ Bug ] Draft: Obsolete wire tools still in contex menu
ahah, do you know that I always thought that the Close button was actually meant to close the command and not the Wire?
thanks for this revelation
Some task panels have two Close buttons. The one with the icon closes the object, and also finishes the command. The other one only finishes the command.
