[ Fixed ] Old Draft_SetWorkingPlaneProxy command name used in gui_planeproxy.py?
Roy_043
Post by Roy_043 »
The Draft_SetWorkingPlaneProxy command has been renamed to Draft_WorkingPlaneProxy. On lines 50 and 51 of gui_planeproxy.py the old name is still used:
             'MenuText': QT_TRANSLATE_NOOP("Draft_SetWorkingPlaneProxy","Create working plane proxy"),
             'ToolTip': QT_TRANSLATE_NOOP("Draft_SetWorkingPlaneProxy","Creates a proxy object from the current working plane.\nOnce the object is created double click it in the tree view to restore the camera position and objects' visibilities.\nThen you can use it to save a different camera position and objects' states any time you need.")}
Should that be fixed or will that break translations?
Roy_043
Re: Old Draft_SetWorkingPlaneProxy command name used in gui_planeproxy.py?
Post by Roy_043 »
Merged.
Re: [ Fixed ] Old Draft_SetWorkingPlaneProxy command name used in gui_planeproxy.py?
Post by Kunda1 »
Thanks!
