[ Fixed ] [ Bug ] Draft_Offset: wrong preview if start angle arc is larger
Roy_043
Post by Roy_043 »
The Draft_Offset preview for Draft_Arcs whose start angle is larger than their end angle is wrong. Not a big issue if you want to enter a distance, the actual offset is correct. But it is a problem if you want to pick a point to define the distance: you cannot select points that can be projected onto the actual arc.
To create such an arc:
  1. Draw the arc CCW.
  2. For the start angle choose between 90 and 180 degrees.
  3. For the end angle choose between 0 and 90 degrees.
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Draft_Offset-arc-bug.FCStd
(3.73 KiB) Downloaded 32 times
Roy_043
Re: [ Bug ] Draft_Offset: wrong preview if start angle arc is larger
Post by Roy_043 »
Merged.
thomas-neemann
Post by thomas-neemann »
Roy_043 wrote: Sat Jul 31, 2021 10:45 amMerged.
thank you
