[ Fixed ] [ Bug ] Draft_Trimex: Angle displayed with wrong units
Roy_043
Post by Roy_043 »
If you Draft_Trimex a Draft_Arc the Distance field in the task panel is replaced by an Angle field. But the units are not changed to degrees.
It is also strange that whereas the distance is a delta value, this is not the case for the angle value.
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Roy_043
Re: [ Fixed ] [ Bug ] Draft_Trimex: Angle displayed with wrong units
Post by Roy_043 »
Merged.
