[ Fixed ] [ Bug ] Draft_SetStyle: Apply to selected button results in error
Roy_043
Post by Roy_043 »
Test:
  1. Select an object.
  2. Call Draft_SetStyle. Either via the Utilities menu or the Draft Tray.
  3. Press the "Selected" button to apply the settings to the selected object.
  4. Result: Error.
    11:28:28 D:\BKG_Tmp\FreeCAD_0.20_Last_Conda\Mod\Draft\draftguitools\gui_setstyle.py(187)<class 'SystemError'>: PyEval_EvalFrameEx returned a result with an error set
    11:28:28 D:\BKG_Tmp\FreeCAD_0.20_Last_Conda\Mod\Draft\draftguitools\gui_setstyle.py(203)<class 'SystemError'>: PyEval_EvalFrameEx returned a result with an error set
OS: Windows 8.1 (6.3)
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Syres
Re: [ Bug ] Draft_SetStyle: Apply to selected button results in error
Post by Syres »
Purely from a consistency point of view, should/could this https://github.com/FreeCAD/FreeCAD/blob ... or.py#L368 be changed to suit in the same PR?
Roy_043
Post by Roy_043 »
Syres wrote: Tue Jun 22, 2021 8:47 am should/could this
Thanks for looking at this.
Internally styles rely on dictionaries in which colors are stored as single integers. That color format is used throughout the implementation. It is only when a color is applied to an object that the color needs to be converted to an RGB list/tupple. At least that is how I understand it.
If you look a little higher in the code you can see how the single integer is converted to RGB numbers:
https://github.com/FreeCAD/FreeCAD/blob ... or.py#L342
Roy_043
Post by Roy_043 »
Merged.
