[ Fixed ] Escape switches off continueMode?
Roy_043
Post by Roy_043 »
At first I thought that the Draft_ToggleConstructionMode command did not work properly. Upon further analysis I find that the "Escape" behavior is causing confusion.
DraftGui.py:
    def escape(self):
        """escapes the current command"""
        self.continueMode = False
        if not self.taskmode:
            # self.taskmode == 0  Draft toolbar is obsolete and has been disabled (February 2020)
            self.continueCmd.setChecked(False)
        self.finish()
IMO the using Esc should not set continueMode to False.
I suppose this function in DraftGui.py should also be changed (but I do not know when it is triggered):
    def Deactivated(self):
        if (FreeCAD.activeDraftCommand != None):
            FreeCAD.activeDraftCommand.finish()
        if self.taskmode:
            FreeCADGui.Control.clearTaskWatcher()
            #self.tray = None
            if hasattr(self,"tray"):
                self.tray.hide()
        else: # self.taskmode == 0  Draft toolbar is obsolete and has been disabled (February 2020)
            self.draftWidget.setVisible(False)
            self.draftWidget.toggleViewAction().setVisible(False)
Roy_043
Re: Escape switches off continueMode?
Post by Roy_043 »
Q&D fix:
    def escape(self):
        if self.continueMode == True:
            self.finish()
            self.continueMode = True
        else:
            self.finish()
Roy_043
Re: [ Fixed ] Escape switches off continueMode?
Post by Roy_043 »
