Slab Direction (solved)
dammerel
Post by dammerel »
Hi all
is it possible to controlled the direction of a slab EG negative or positive
Andrew
Roy_043
Re: Slab Direction
Post by Roy_043 »
If the Base of the slab is a wire you can reverse the wire with the Draft_Edit command. Else you can change the Normal of the slab.
dammerel
Re: Slab Direction (solved)
Post by dammerel »
Thanks again
Andrew
