Room recognition and schedule
Is there a way for FC to designate spaces as actual rooms in a building model and generate a table listing the room numbers and their respective areas? Please say yes!
Re: Room recognition and schedule
Moved to Arch forum.
Basically there is ArchSpace you can use in the first place, here is forum announcement.
Seems has a script to generate a schedule in a discussion.
More experimental discussion probably.
Good luck
- thomas-neemann
My customers also have questions like this. there are several departments, e.g. construction, tender, statics, etc.
nobody wants to do more work so that someone else can make it easy.
i can only imagine one case where it makes sense. in a 1 man office, where everything is done by one person. the only question is whether the programming effort is worth it
