In the attached file. I have used Arch Roof (https://wiki.freecadweb.org/Arch_Roof) to produce a roof.
I am aware of the note in the Arch Roof documentation (Note: This tool is still in development, and might fail with very complex shapes).
The result was satisfactory except for some minor issues.
All ridges lines are correct as expected (dotted red lines, attached image). There are 4 areas/corners of the roof not right, FC did not trim them as expected (I have marked them with red cross, refer to attached image).
Am I missing something or I reach the current development limitation (very complex shapes)? Please comment
Arch Roof - development limitation
- New OpenDocument Drawing.jpg (127.9 KiB) Viewed 884 times
- Model-R5.FCStd
- (69.87 KiB) Downloaded 23 times
Re: Arch Roof - development limitation
The algorithm only compares adjacent roof panels, or, in the case of gables, panels attached to the same gable.
You can work around this by creating the roof in two parts. Bottom part: gutter to lower ridges, top part: lower ridges to top.
I was able to reach your other posts (https://forum.freecadweb.org/viewtopic. ... =4&t=51382). It is very helpful. I will keep searching to learn more. I am still trying/learning how to get around it. Thanks
