BIM-Workbench Changes Working Plan
Palmtree
Post by Palmtree »
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
To reproduce the issue please refer to the following:
  • Go preferences ==> Make your default current working plane "Top" refer to (refer to image 1). Restart FC.
  • Open the attached FC test file. Note that the FC menu bar showing working plane "Top" (refer to image 2)
  • Go to draw a rectangle ==> Menu ==> 2D Drafting ==> Rectangle.... whoops the working plan is changed to align to view (refer to image 3)
I expect to start on a "Top" working plane not on the other! (refer to image 4). Is this normal? Please comment.
Model-R6.FCStd
(69.06 KiB) Downloaded 17 times
Roy_043
Re: BIM-Workbench Changes Working Plan
Post by Roy_043 »
I cannot reproduce this. Maybe there is an issue with your user.cfg file. After restarting please check the preferences to verify that the "Default working plane" is in fact set to the correct value.
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Palmtree
Post by Palmtree »
I deleted both (system.cfg & user.cfg) ==> Restart FC... No Luck still doing the same issue.
I hope somebody will be able to reproduce it on a different computer with Win 10.
Thanks
Roy_043
Post by Roy_043 »
There is a related issue if you restart after removing user.cfg:
https://forum.freecadweb.org/viewtopic. ... 11#p513411
After removing the file you should again set the preference and restart. You also need to make sure that only a single instance of FreeCAD is active when you set a preference.
