[ Fixed ] Draft_SelectGroup is confusing
Roy_043
Post by Roy_043 »
Looking at the Draft_SelectGroup command I find the results somewhat confusing.
Issue 1: nested_groups.png and nested_groups.FCStd
On the left the Group was selected. On the right the Circle was selected.
The selections are different, but if you invoke the Draft_Move command you will end up moving the same objects (all circles). So why is there this difference and when is it useful? On the left I would expect Group001 and Group002 to also be selected.
Issue 2: groups_and_layers.png and groups_and_layers.FCStd
Objects can occur multiple times in the Tree view. This will certainly be the case when layers are used. The command does not handle this situation well. In the image Line003 in Group was selected.
Issue 3: see Issue2
The command is called Draft_SelectGroup but also selects layers. If this is intended behavior the command name is confusing. Compare the Draft_AddToGroup command which does not work with layers (although it does, wrongly IMO, show the 'Layers' group).
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
nested_groups.FCStd
(12.88 KiB) Downloaded 59 times
(18.62 KiB) Downloaded 46 times
Roy_043
Re: Draft_SelectGroup is confusing
Post by Roy_043 »
Roy_043 wrote: Fri Jul 16, 2021 8:48 pm Draft_AddToGroup command which does not work with layers (although it does, wrongly IMO, show the 'Layers' group)
As a side-effect of PR4879 the Draft LayerContainer no longer appears in the Draft_AddToGroup menu.
https://github.com/FreeCAD/FreeCAD/pull/4879
Re. Draft_SelectGroup issue 2:
The situation is more complex:
What if the user selects an object in the 3D view and the object occurs in a layer and a group? Should the content of the layer or the group be selected? Or both?
An object can even occur in multiple layers (this can be achieved by editing their Group property).
Maybe Draft_AddToGroup and Draft_SelectGroup should be restricted to groups and group-like Arch objects, and to handle layers two new commands should be added?
For Draft_SelectGroup it may work to only consider the items selected in the Tree view. But then the purpose of the command becomes somewhat lost. In the tree you may as well select the group the object is in.
Roy_043
Post by Roy_043 »
Roy_043
Re: [ Fixed ] Draft_SelectGroup is confusing
Post by Roy_043 »
Merged.
