[ Bug ] "Flatten this wire" has some issues
Roy_043
Post by Roy_043 »
Rather by accident I discovered that there is a "Flatten this wire" option in the Tree view context menu for Draft_Wires, Draft_Fillets, Draft_BSplines, Draft_CubicBezCurves and Draft_BezCurves.
Issue 1: Bug
If the placement of the wire does not match the default placement the command will move the wire.
Issue 2: Bug
The command cannot work for Draft_Fillets. See Issue 3. So the option should not be displayed for that object.
Issue 3:
IMO the implementation is somewhat unexpected as the current working plane is not used as the projection plane. The projection plane is derived from the object instead.
Issue 4:
IMO this option should removed from the context menu and added to Draft_Edit edge menus. Compare the "reverse wire" option.
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Roy_043
Re: [ Bug ] "Flatten this wire" has some issues
Post by Roy_043 »
