[ Fixed ] Annotation scale widget: problem with display of certain scales
Roy_043
Post by Roy_043 »
The Annotation scale widget does not display the 5:1, 10:1 and 20:1 scales properly after a restart.
Test:
  1. Startup WB is Draft.
  2. Change the scale in the Annotation scale widget to "20:1"
  3. Restart FC.
  4. The scale is displayed as "20.0".
The problem is related to floating point accuracy and the as_integer_ratio method used in the scale_to_label function.
https://github.com/FreeCAD/FreeCAD/blob ... ar.py#L102
>>> 0.2.as_integer_ratio()
(3602879701896397, 18014398509481984)
Maybe the function should look like this:
def scale_to_label(scale):
    transform a float number into a 1:X or X:1 scale and return it as label
    f = round(scale, 2)
    if f == 1.0:
        return "1:1"
    elif f > 1.0:
        f = f.as_integer_ratio()
        if f[1] == 1:
            return str(f[0]) + ":1"
        else:
            return str(scale)
    else:
        f = 1/scale
        f = round(f, 2)
        if f[1] == 1:
            return "1:" + str(f[0])
        else:
            return str(scale)
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Roy_043
Re: [ Fixed ] Annotation scale widget: problem with display of certain scales
Post by Roy_043 »
Merged.
thomas-neemann
Post by thomas-neemann »
Roy_043 wrote: Mon Sep 20, 2021 7:01 pmMerged.
thank you for your effort to correct all these things.
Roy_043
Post by Roy_043 »
Thanks, but this is really minor stuff.
carlopav
Post by carlopav »
Roy_043 wrote: Wed Sep 22, 2021 7:31 am Thanks, but this is really minor stuff.
It's not! There is a huge space for improvements in every single aspect of Draft, and this little fixes are very important for the overall perception of the quality of the code and of the software as a whole.
So thanks for the time you dedicate to the project, and sorry for the bugs i'm spreading around :oops:
paullee
Post by paullee »
Indeed, fixing bug is important ! Thanks everyone here ! :)
