Draft style: something wong with defaults?
Roy_043
Post by Roy_043 »
If I restart FC after deleting user.cfg the Draft Tray shows a text size of 0.20mm (which is tiny).
I click the style button, the Style settings task panel opens, and the Text size (Tekstgrootte) is 10.0 mm instead of 0.20mm.
I press Cancel.
A Draft_Text created at this point has a Font Size of 0.20mm.
In the Preferences I change the language to from Dutch to English.
Again I click the style button in the Draft Tray. The text size now is 0.20mm. And several other settings have also changed, namely: Text spacing, Arrow size and Text font. Notice that the size settings are not scaled by the same factor.
I do not understand this.
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
thomas-neemann
Re: Draft style: something wong with defaults?
Post by thomas-neemann »
Roy_043 wrote: Fri Jul 23, 2021 1:21 pm
I can confirm these effects. there are still more of them. e.g. the default working level in draft. it is faded in automatically, but is actually at the top.
if you open the settings once, click on apply and restart everything is ok.
At the moment it is probably the case that the freecad only works well after installation, after the settings are changed for the first time and restarted.
Roy_043
Post by Roy_043 »
thomas-neemann wrote: Fri Jul 23, 2021 6:19 pm I can confirm these effects
Have you tested the issue in my post, or are you only speaking more generally here?
thomas-neemann
Roy_043 wrote: Fri Jul 23, 2021 6:50 pm
I can confirm that after clicking the style button and then ok, 10 mm is then active. even after restart.
why do you press cancel?
Roy_043
Post by Roy_043 »
thomas-neemann wrote: Fri Jul 23, 2021 7:45 pm why do you press cancel?
To demonstrate that changing the language has an impact on the defaults.
Roy_043
Post by Roy_043 »
Side note: The S,S shortcut of the Draft_SetStyle command is already used by Draft_ShapeString.
Roy_043
Post by Roy_043 »
Roy_043 wrote: Wed Jul 28, 2021 12:24 pm Side note: The S,S shortcut of the Draft_SetStyle command is already used by Draft_ShapeString.
This has been fixed.
https://github.com/FreeCAD/FreeCAD/pull/5179
