Align Draft working plane with Arch_Axis?
Roy_043
Post by Roy_043 »
I do not understand how to align a Draft working plane with an Arch_Axis. I remember a discussion about this, and there is some dedicated code:
https://github.com/FreeCAD/FreeCAD/blob ... ne.py#L196
Test:
  1. Open the attached file.
  2. Align the WP with the face of the circle.
  3. Select the Arch_Axis in the 3D view.
  4. Invoke Draft_SelectPlane.
  5. Start the Draft_Line command f.e.
  6. Toggle the grid if required.
  7. Result: the WP is still aligned with the circle.
align-wp-to-axis.FCStd
(6.03 KiB) Downloaded 22 times
thomas-neemann
Re: Align Draft working plane with Arch_Axis?
Post by thomas-neemann »
Roy_043 wrote: Sun Jul 25, 2021 4:52 pm
if i want the working plane in a certain position, i create a triangle with draft polygon.
Roy_043
Post by Roy_043 »
Using a Draft_WorkingPlaneProxy would make more sense then. But I am specifically interested in the Arch_Axis option. I need to know how it works because I am working on the documentation of the Draft_SelectPlane command.
thomas-neemann
Roy_043 wrote: Sun Jul 25, 2021 8:13 pm
yorik should be able to answer that
paullee
Post by paullee »
This sounds great :)
In fact, other than laying out 'cosmetically' on a drawing, not sure how ArchAxis actually integrate in a modelling workflow. Anybody has any idea ?
Roy_043
Post by Roy_043 »
You can snap to intersections and endpoints of an Axis System. Other than that I do not know.
Roy_043
Post by Roy_043 »
The algorithm used to check the selected object is a bit complex IMO. And as a result hard to document.
I wonder if it can be simplified:
If subelements are selected: Use those to calculate the plane.
If a single object and no subelements are selected: Use the Placement of that object.
Or would that break exiting functionality too much?
