[ Fixed ] Draft_SelectPlane: issue with display of negative snapRange
Roy_043
Post by Roy_043 »
A small issue:
If you change the snapRange 'on-the-fly' (see Draft_Snap) the value can become negative if you use the decrease key: "]".
A negative value seems to work fine for Draft_Snap_Grid, but in the task panel of the Draft_SelectPlane command a negative value is displayed as zero.
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
thomas-neemann
Re: [ Bug ] Draft_SelectPlane: issue with display of negative snapRange
Post by thomas-neemann »
thank you
Roy_043
Re: [ Fixed ] Draft_SelectPlane: issue with display of negative snapRange
Post by Roy_043 »
Merged.
