Arch Wall and Window Do Not Move Together
Re: Arch Wall and Window Do Not Move Together
I think everybody can go to the bugtracker to report and edit status etc ?
- ragohix769
That's true, I'll try (never done anything on a bugtracker, but I can learn)
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
- thomas-neemann
here is a workarond. is that a solution for you? even transforming is possible with it
https://www.youtube.com/watch?v=J-sgXyYMDB0
- ragohix769
So you propose to make a compound everytime (Window+wall), make the move, and then de-compound?thomas-neemann wrote: ↑Thu Aug 05, 2021 5:29 pmhere is a workarond. is that a solution for you? even transforming is possible with it
It's a nice workaround, I'll try.
- thomas-neemann
yes, but not, if the window is to be moved in the wall, this would have to be done beforehand.
I changed the Severity to Major in the bug tracker report.thomas-neemann wrote: ↑Thu Aug 05, 2021 8:20 pmyes, but not, if the window is to be moved in the wall, this would have to be done beforehand.
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Is anyone working on this issue...just wondering.
- thomas-neemann
Another workaround can be seen here in the first minute. the windows remain transparent
https://www.youtube.com/watch?v=oxGZwWXnrMI
Thank you for taking the time to reply.thomas-neemann wrote: ↑Sat Oct 16, 2021 11:48 amAnother workaround can be seen here in the first minute. the windows remain transparent
I have found a workaround, which is to connect the placement coordinates of the window with the wall.
Would work if the edges in Sketch is not aligned vertical / horizontal ?
