[ Fixed ] Draft_ToggleGrid does not work when a command is active
Roy_043
Post by Roy_043 »
Just reporting...
In V0.18 you can toggle the Draft grid while a command is active. Note you have to use the Draft_ToggleGrid button. And this setting is remembered for the current FreeCAD session.
In V0.19 and V0.20 this is no longer possible. When the pointer enters the 3D view after using the Draft_ToggleGrid button, the grid is always switched on.
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
ragohix769
Re: [ Bug ] Draft_ToggleGrid does not work when a command is active
Post by ragohix769 »
I confirm this problem/bug (very very annoying).
OS: Ubuntu 18.04.5 LTS (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: 6fed5236b9a5bba80d1d086cda6ff7472f07a603
Python version: 3.6.9
Qt version: 5.9.5
OCC version: 7.5.2
Locale: Italian/Italy (it_IT)
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough :-(
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same :-)
Syres
Post by Syres »
I believe this is the preference setting which controls the grid activation in the 3D Viewport:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.25306 (Git)
Hash: 5f5b3d9b67136edda1f6738f1a83154990f7839d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
ragohix769
IMHO anyway it's a bug, because if you deselect completely the grid from preferences, it's not an option; it should permit to disable the grid temporarly as it appear normally when you don't have a command active.
Syres
Post by Syres »
Roy_043
Post by Roy_043 »
The fix works but it does not restore the V0.18 behavior. The "Use grid" preference in V0.18 completely disables the grid. After changing it you even have to restart FreeCAD. And toggling the grid works without changing this preference.
Roy_043
Re: [ Fixed ] Draft_ToggleGrid does not work when a command is active
Post by Roy_043 »
Merged.
