[ Fixed ] Transparency of Draft_Layer has incorrect type
Roy_043
Post by Roy_043 »
The Transparency of a layer has the wrong type: "App::PropertyInteger" instead of "App::PropertyPercent". Easy to fix in the code of course. But I wonder if this requires a migrate function or is that overkill?
    # To be added to the Layer class and called from onDocumentRestored (layer.py).
    def _migrate_0_19_to_0_20(self, obj):
        if App.GuiUp:
            vobj = obj.ViewObject
            if (hasattr(vobj, "Transparency")
                    and vobj.getTypeIdOfProperty("Transparency") == "App::PropertyInteger"):
                trans = vobj.Transparency
                vobj.removeProperty("Transparency")
                vobj.Proxy.set_visual_properties(vobj, vobj.PropertiesList)
                vobj.Transparency = trans
Roy_043
Re: Transparency of Draft_Layer has incorrect type
Post by Roy_043 »
Roy_043
Re: [ Fixed ] Transparency of Draft_Layer has incorrect type
Post by Roy_043 »
Merged.
