[ Fixed ] 3 small issues with Draft Patterns
Roy_043
Post by Roy_043 »
3 small issues with Draft Patterns:
  • The Pattern list has a random order.
  • The diagonal1 and diagonal2 pattern seem identical.
  • In the source code there are 2 additional patterns that do not appear in the list: hatch45L and hatch45R. See Artwork_Draft.
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Roy_043
Re: 3 small issues with Draft Patterns
Post by Roy_043 »
I have meanwhile found out why hatch45L and hatch45R do not appear in the list. They are derived from the simple.svg pattern and still used that name as their id:
<pattern height=".1" width=".1" y="0" x="0" patternUnits="userSpaceOnUse" id="simple">
If this is fixed then maybe simple.svg should be deleted?
EDIT: Deleting simple.svg is tricky. Patterns are not save with the document. So users who have applied this pattern will still need the file.
Roy_043
Post by Roy_043 »
Roy_043 wrote: Wed Aug 11, 2021 8:43 am The diagonal1 and diagonal2 pattern seem identical.
This is probably due to the hatch resolution. This value is currently hard-coded.
The other 2 issues should be fixed with:
https://github.com/FreeCAD/FreeCAD/pull/5060
Roy_043
Re: [ Fixed ] 3 small issues with Draft Patterns
Post by Roy_043 »
Merged.
